1. Rumblee1's Avatar
    I've got all of my music on an SD card. It started to sound a bit distorted today. I originally thought that I blew my headphones, but when I plugged them into another device, they worked fine. Could it be the SD card starting to go? Any other ideas would be helpful. Thanks.
    11-02-2016 09:57 AM
  2. amyf27's Avatar
    Not an expert but it can be the card. Is it old ? I've had other phone issues occur when the sd memory card went bad
    11-02-2016 10:16 AM
  3. KyuuBun's Avatar
    Does it also happen on the phones speaker or just headphones? Also if you have not tried this try rebooting the phone and see if it clears up. I had this issue with my black S7 edge a few times and a restart fixed it.
    11-02-2016 11:33 AM
  4. Rumblee1's Avatar
    Truthfully, yes. Same card I had in my Galaxy Note 4 so it's a few years old
    11-02-2016 02:48 PM
  5. Rumblee1's Avatar
    I'll have to try them when I get home not able to do that right now and I'll repost good point though
    11-02-2016 02:48 PM
  1. bluetooth/ equalizer issue with Google play music
    By flipbeats in forum Nexus 6P
    Last Post: 11-05-2016, 12:29 AM
  2. Note 4 download and connection issues
    Last Post: 11-02-2016, 03:00 AM
  3. Issue with Android Internal Storage?
    Last Post: 11-02-2016, 12:18 AM
  4. S7 Active sound cuts out
    Last Post: 11-01-2016, 10:16 PM
  5. How do I fix my Samsung Tab 4 sound?
    By Jess the Mess in forum Ask a Question
    Last Post: 11-01-2016, 07:47 PM
