02-25-2021 05:37 AM
26 12
tools
  1. David Rosen's Avatar
    Sigh... I've made it pretty long without any major issues with my Galaxy S7 Edge, but now I've got one. I'm not sure if this started with the last update (or the update before that)... But I've read online about the update being the culprit, so that's why I mention it...
    If I choose to store photos on my SD Card, as soon as I go to take a photo it says "Unable to save file to SD Card. Default storage has been changed to device memory."
    The SD card is fine. My phone is running fine otherwise. Other files can be written and read from the SD card. It's a high quality Samsung card (forget the exact model but one of the top of the line ones). Only 3gb of 128gb are even being used yet.
    It never used to be like this. When I got the phone SD card was selected and it saved the photos to the SD card like it's supposed to.
    Any ideas? I really don't want to start formatting and wiping and restoring and all that. This is so annoying.
    11-02-2016 03:47 PM
  2. SpookDroid's Avatar
    Can any other camera apps write to the SD Card? Not read...write. The first time I saw that happen on mine, BOOM, yet another SD Card fried by a Samsung phone. Fortunately I learned my lesson a long time ago and I never save pictures to SD card (I was trying out that in the camera because I saw some glitches in the SD card).
    11-02-2016 04:29 PM
  3. David Rosen's Avatar
    what's a good not spammy camera app i can install that can write to SD that I can test? i only have the main camera app and camscanner (which can't save to SD) and instagram which i don't think can either.
    11-02-2016 04:46 PM
  4. Rukbat's Avatar
    ANY app can save to a folder it created on the SD card. It can't save to a folder another app created. (Assuming that it's written to give you a choice.)
    That's probably the problem you're having - trying to save to some other app's folder (or to the root of the card - which is effectively root's folder)..
    11-02-2016 05:01 PM
  5. David Rosen's Avatar
    but i'm not trying to save to any specific folder. i'm just choosing SD Card as the location for the built in camera app to save photos and videos to as it takes them. so what you're describing is that IT is the one screwing up, not me haha. it's not asking me what folder to save photos in. it's just Device Storage or SD Card. that's the only two options.
    11-02-2016 05:05 PM
  6. SpookDroid's Avatar
    But the camera app (at least the stock one) shouldn't have that problem. Plus, it never really asks you where to save the photos, just changes it to SD card, effectively just creating the folder there and saving pictures. I still think the card is about to or already gone kaput. Sammy doesn't seem to get SD Cards right on their phones Been churning and burning and chewing through SD Cards since the Note 2 in my case.
    11-02-2016 05:07 PM
  7. David Rosen's Avatar
    I really hate to say this, and I know that a million other people will probably disagree with you, but I think you're probably right. I've posted many times about how my Android phones always start having issues with an SD card installed... And all of my Android phones except two have been Samsung... I think Samsung just murders SD cards... I suppose it wouldn't kill me to format the card to see if that helps... I don't know, I kind of am feeling pretty negative about it haha.
    11-02-2016 05:10 PM
  8. David Rosen's Avatar
    Stupid 32gb internal storage being the only option from T-Mobile phone...
    SpookDroid likes this.
    11-02-2016 05:11 PM
  9. lammy8's Avatar
    I've only ever had non Samsung cards die on me in their phones. Curious....
    Speculation aside, have you tried resetting the camera settings to default, cache clearing, tried a different card etc?
    11-02-2016 06:52 PM
  10. Jaycemiskel's Avatar
    That's crazy. Every one of my phones has had no problem with the SD card *knock on wood*. Guess some people just have bad luck.
    11-02-2016 08:08 PM
  11. IAmSixNine's Avatar
    Look at your SD card and see if it has
    /DCIM/Camera
    Thats where my photos are being stored by selecting SD card on my stock camera app.
    If NOT perhaps the card was not formated correctly by android and this location doesnt exist thus confusing the app.
    jimd1050 likes this.
    11-03-2016 11:08 AM
  12. David Rosen's Avatar
    wow even though storage shows that 4.03gb of the 128gb is used, when i go to the sd card in My Files, it shows no files. So maybe the phone did ruin the card... i'm gonna put it in a computer later and see if it can access anything and if not i'll format the card and see what happens.
    11-04-2016 02:29 PM
  13. SpookDroid's Avatar
    Some of those might be 'hidden' files, though, like if you download music from Play Music, etc. But yeah, I don't trust Samsung with SD cards anymore
    11-04-2016 02:44 PM
  14. David Rosen's Avatar
    OH ok then that might make sense, because the only thing I use my SD for is the camera and saving music for offline play in Google Play Music, Spotify, and Howl Podcasts. Otherwise I don't even touch the SD card.
    However there's definitely no DCIM folder like there should be when viewed in My Files or via a USB Cable on my PC at work (I don't have an SD Card reader here)
    11-04-2016 02:56 PM
  15. WingLT's Avatar
    I can't tell you how many times my Samsung phones ruined my SD Cards. Yes they were third party cards. This time I'm using a Samsung card. And it better work for a long time.
    11-06-2016 01:54 PM
  16. JOC2016's Avatar
    I got the same message when I tried to get mine to save pictures to the SD card. I wondered if it might be worth formatting the SD card actually inside the phone. The only problem with that is that I like to have my music also on my SD card (its quicker for backups if I do music separately from my PC to and from the SD card). so if its formatted in the phone it may not be compatible with the PC.
    11-06-2016 04:23 PM
  17. SpookDroid's Avatar
    My last S7 Edge, unfortunately, did end up damaging a Samsung card (the one I got from the promo from the original S7 Edge haha).
    11-07-2016 11:47 AM
  18. WingLT's Avatar
    NOOOOOOO!!!!!!!! Don't say it! Now I'll be worried about it happening again.
    11-08-2016 08:07 PM
  19. SpookDroid's Avatar
    Just like the next big meteor hitting Earth: the question is not IF, but WHEN. (Read in Morgan Freeman's voice)
    My advice? Don't keep anything in an SD card that's important or not already backed up. Use it for media consumption only and stick to stuff that you have elsewhere.
    11-09-2016 11:17 AM
  20. David Rosen's Avatar
    OK so a little update on this post (I've been busy getting ready for a Thanksgiving trip so didn't get to mess with it for a couple weeks).
    I tried copying all the stuff on the SD card onto my computer to back it up. It did it fine. The images on the card are readable on both my PC and my Galaxy s7 edge.
    Then I tried to format the card in both the computer and the phone, and both failed because the card is write protected. There's no write protection switch on the card (I don't think microSD normally has one anyway, right?).
    Android and Windows both can't write to the card, only read. And can't format.
    So now we know there's a major issue here haha. Do you think the card is toast? If so do SD cards usually last less than a year because like I said previously, I feel like I've never had a phone's SD Card last more than a year before problems arise (which I always attribute to the phone and never really consider "Oh maybe the card is bad"). Any ideas?
    11-28-2016 10:35 AM
  21. David Rosen's Avatar
    Well I just finally grabbed an an old SD Card of mine and formatted it and it works. can store images to SD direct from the camera app the way it's supposed to and everything.So I guess my 128gb card was murdered by that Android System Updates... Once again, System Updates are the worst. I don't know why people sit around complaining how their phone hasn't gotten the latest version of Android... Phones become garbage once they get updated every time. My last phone, the Moto X Pure was the best phone I've ever owned other than the camera (which is why I switched to the S7 Edge) and then it got a system update and it was never the same again. Luckily performance on the S7 Edge didn't take a hit after the latest update and it just ruined a perfectly good SD card. I wonder if the card has warranty... Just thinking out loud haha.
    Anyway, problems solved by switching to a new card. Blah.
    11-29-2016 10:42 AM
  22. HMBgal's Avatar
    I back up everything to my Dropbox account. Just too many issues and flaky stuff happening with updates, etc. I just threw in the towel and now have a couple of TBs of storage and my pictures and stuff backs up automatically. I have to upload on WiFi only, although if I was taking really important pictures, I would reset it to upload immediately.
    11-30-2016 10:14 AM
  23. nico1et's Avatar
    I know this is old, but others might run into the same problem if their device does a nougat update. (my little Tab A did recently & I've had numerous problems since then, including the exact same thing with the unable to save to sd card error - when it worked perfectly before)
    sorry, I DO NOT believe it's a problem with the card. happened right after the update, which changed pretty much everything, & made some things unusable.
    hopefully my latest thing fixed this problem. I went into the settings/storage.. to where I could click on SD card itself (not on the photos etc area) & to where it had the "unmount" option. I unmounted, & then mounted... then I went back to options within the camera app & changed the settings back to sd card (which would act like it was sticking earlier, but wouldn't as soon as I tried taking a photo). then I took a couple photos & never got the "unable to..." error.
    hope that helps anyone else doing a search for a solution for this problem even as late as 2017.
    11-30-2017 11:53 AM
  24. nico1et's Avatar
    well, it worked enough to save a few photos to the card like before, but now it's saving to internal memory.
    sorry, I don't agree that the card is mysteriously toast just due to the update. this happened immediately after that lame (marshmallow?) update that screwed other things up on this little Samsung Tab A also.
    just the fact that it WILL save to SD card proves that it CAN. it's the update & the way it screwed with the system workings that's the problem.
    wish there was a way to turn back the clock, but from what I've seen, there's no way. highly irritating & makes me want to buy no more samsungs, or at the very least, make sure I DE line each & every update (like I learned to do with all iPads after the 1st one).
    12-28-2017 03:03 PM
  25. Rukbat's Avatar
    1. You can turn the clock back - SamMobile Firmwares. Back up, flash the last firmware, then restore.
    2. Unless you root, the device will ask you if it should update about 15 times - then it will update without asking. If you root, you can disable the updater app, or you can just let it update, and the update will "fail" as soon as it sees that the device is rooted (about 25% of the way through).
    12-29-2017 05:14 PM
26 12
  1. Removing PIN to decrypt device on startup
    Last Post: 11-04-2016, 09:08 AM
  2. How to organize pictures, etc.?
    Last Post: 11-02-2016, 05:38 PM
  3. Replies: 1
    Last Post: 11-02-2016, 05:02 PM
  4. Replies: 1
    Last Post: 11-02-2016, 04:34 PM
  5. Airplane Mode Unable to find Specific Wifi Networks
    By converge0 in forum Android 6.0 Marshmallow
    Last Post: 11-02-2016, 03:19 PM
