1. Nick_1020's Avatar
    I got my S7 Edge today. So far, so good. Lovely looking phone and the GPS is much improved over the Note 4 performance.
    I plan on restoring apps and data from TiBu backups taken on my Note 4 but I'm wondering what is the best way to do this?
    I'll need to root the Edge and after that is it just a case of installing TiBu and the sd card which has the backups and restore? Are there any apps/data that cannot be transferred to a new device? Also, will I have to purchase a new license for TiBu?
    Thanks for any help.
    11-03-2016 07:12 AM
  2. Deke218's Avatar
    You'd be better of reloading your apps from the Playstore. TB is great when restoring to the same device but restoring to a different device always causes problems. Force closings, constant reboots and other less than desirable performance issues. While it may take longer, you'll end up with a better experience.
    To answer your question, you will not have to purchase a separate license. Once you buy it, you own it.
    11-04-2016 12:30 AM
  3. Nick_1020's Avatar
    Managed to sort it. Rooting was straightforward and restoring apps and data seemed to go through smoothly too.
    No problems so far.
    Although my SD card seems to be on it's last legs. Was a huge pain trying to backup files to my computer as quite a few refused to budge due to I/O errors. Tried a quick format but the problems are persisting. Chkdsk didn't find any errors in read/write mode so as a last resort, I'm trying a low level format but it's going to take forever as the speed has dropped to about 1.4MB/s.
    11-04-2016 09:13 AM
  1. Why I always have to reinstall my Japanese language keyboard
    Last Post: 11-04-2016, 10:02 AM
  2. Is there any say to bypass a lock code on the EM756 tablet?
    Last Post: 11-03-2016, 04:31 PM
  3. Replies: 1
    Last Post: 11-03-2016, 04:30 PM
  4. says that I need to enable cookies on web browser
    Last Post: 11-03-2016, 03:03 PM
  5. How to recover data from broken moto g phone?
    Last Post: 11-03-2016, 03:18 AM
