1. hishaq96's Avatar
    Hi my s7 edge is lagging too much I've cleared the cache partion and have done factory resets in the past but still the same.
    11-03-2016 10:24 AM
  2. IAmSixNine's Avatar
    Are you restoring your device after each factory reset?
    If so then your not really doing much. Restoring a back up will essentially put the same problem back onto your phone.
    If you have an app not acting properly you need to wipe your device and install about 5 to 10 apps on it a day till you notice the lag, then hopefully one of the last 10 is whats causing it.
    Could also be an issue with an SD card as well.
    11-03-2016 11:01 AM
  3. hishaq96's Avatar
    Thanks yh I installed around 5 apps a day and still seems to lag
    11-03-2016 11:46 AM
  4. victoryrules8's Avatar
    It's TouchWiz it's not your device . Seriously mine does it too . Every Samsung I've owned it has lagged. Regardless of what people may say. It's TouchWiz and always will be until they worknout even more kinks
    11-03-2016 11:56 AM
  5. hishaq96's Avatar
    Yh I've had the same problem from my previous Samsung device
    11-03-2016 12:10 PM
  6. IAmSixNine's Avatar
    Mine seems to run well. I noticed lag a few weeks ago when google photos had an issue but its back to normal.
    11-03-2016 01:28 PM
  7. simon bannister's Avatar
    Mine has been suffering from the same lag ever since the last update. It worked flawlessly before that.
    11-03-2016 01:31 PM
  8. WallaceD's Avatar
    The only "lag" I have experienced on the S7 Edge occurred when there was a problem with a background service or application.
    11-03-2016 01:44 PM
  9. ThrottleJohnny's Avatar
    My Edge only lags with WiFi issues. Otherwise, smooth sailing.
    11-03-2016 01:56 PM
  10. Gary02468's Avatar
    What are the circumstances, manifestations, and durations of the lag? People use the term to refer to all sorts of different things, ranging from normal animation transitions to genuine device stuttering. (Posting a brief video would be helpful.)
    At what point in that process did the lag resume?
    11-03-2016 02:05 PM
  11. hishaq96's Avatar
    It's not the animation it's the device as I've changed the animation. The device started lagging yesterday and I did the reset last week
    11-03-2016 02:13 PM
  12. Gary02468's Avatar
    Ok but it would still help to know what lags, for how long, and under what circumstances.
    What were the five apps you restored the day the lag resumed?
    11-03-2016 05:00 PM
  13. H2o's Avatar
    I was getting terrible lag. Did a little research and uninstalled the oculus app(s) cleared it right up without having to do a factory reset.
    11-03-2016 06:09 PM
  1. Replies: 30
    Last Post: 01-26-2017, 02:01 PM
  2. Read receipts on Samsung Galaxy S7
    Last Post: 11-04-2016, 10:16 AM
  3. Replies: 0
    Last Post: 11-03-2016, 10:02 AM
  4. Verizon S7 on ATT ??? Work ?
    By harleymhs in forum Samsung Galaxy S7
    Last Post: 11-03-2016, 08:58 AM
  5. Galaxy S7 edge adds or changes characters
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 11-03-2016, 07:55 AM
