1. chwaffles's Avatar
    Is there any way to save my data-pics/music, etc. to my MacBook pro without having to access anything on my phone because my screen is completely busted?
    11-04-2016 02:11 AM
  2. B. Diddy's Avatar
    Moved to the S7 edge forum.
    11-06-2016 12:50 AM
  3. bandofbrothers2112's Avatar
    Did you have these on a Sd card ?
    What happens when you hook up to your computer?
    Did you use any iCloud options or Dropbox etc.
    11-06-2016 01:36 AM
  4. mavrrick's Avatar
    Try loading sidesync to your computer and then attach the phone via USB.
    11-06-2016 06:41 AM
  5. wookiee2cu's Avatar
    Not sure about Mac's but when I connect mine to a PC, on the phone I have to select "allow" or something like that for the computer to access the phone.
    11-07-2016 06:01 PM
  1. My Flare S4 Lite wont open
    Last Post: 11-04-2016, 06:20 AM
  2. can't get the back cover off my zte n817?
    Last Post: 11-04-2016, 06:17 AM
  3. how do i unblock wifi access on my phone ?
    Last Post: 11-04-2016, 05:55 AM
  4. Why is my Android Calendar App duplicating entries?
    Last Post: 11-03-2016, 11:59 PM
  5. Replies: 0
