1. aldo82's Avatar
    Has any one else had this problem? When I charge over night I switch off quick charge. From time to time the phone doesn't fully charge despite being plugged in for 7 hours. Is this the phone or the charge? Quick charge always seems to be reliable. And slow charging works fine probably 90% of the time.
    Is it OK to just leave quick charge on all the time or will it degrade the battery faster?
    11-04-2016 05:23 AM
  2. Nakrohtap's Avatar
    You never stated if you're using the stock charger and cable. I would think it's one of those and not the phone.
    11-04-2016 06:30 AM
  3. aldo82's Avatar
    Stock charger and cable. Strange that it handles fast charge fine, just slow charge is unreliable
    11-04-2016 06:36 AM
  4. ABOSWORTH007's Avatar
    That is strange. I've never turned off the quick charge feature to try. I do notice that it doesn't fully charge on my wireless charger sometimes though.
    KPMcClave likes this.
    11-04-2016 08:05 AM
  5. Nakrohtap's Avatar
    I've heard this as well with some wireless chargers when reading through some of the reviews when I bought mine.
    11-04-2016 08:17 AM
  6. Nakrohtap's Avatar
    Do you have another charger you can test out? You may have gotten a bad one where it shuts off once it hits 100% and doesn't turn back on.
    11-04-2016 08:19 AM
  7. ABOSWORTH007's Avatar
    It doesn't do it very often. I find that I really have to make sure it's centered on the charger. It just happens every once in a while so I'm not too bothered by it. It is a Samsung Wireless Charger.
    11-04-2016 08:29 AM
  8. WalkingHorse's Avatar
    Exact same situation here. I charge overnight on a Samsung wireless charger and I would say about every 7 to 10 days it doesn't do a full charge (stops around 78%). I'm not too bothered by it either.
    KPMcClave and ABOSWORTH007 like this.
    11-04-2016 09:42 AM
  9. KPMcClave's Avatar
    Every once in a while mine won't fully charge overnight. It's fairly infrequent and it's via a 3rd party wireless charger. I figured I must bump the allignment moving in my sleep (it's on a tbale by my bed), even though I've doubted that's the case.
    ABOSWORTH007 likes this.
    11-04-2016 09:43 AM
  10. KPMcClave's Avatar
    My non-OEM wirless charger seems to stop around 80% when that happens. I'd estimate it has happened to me less frquently than 7-10 days.
    11-04-2016 09:44 AM
  11. aldo82's Avatar
    Interesting that people seem to get the same problem using wireless charging yet mine is using wired. I'll try a different charger to see what's going on
    11-04-2016 09:52 AM
  1. Do not disturb doesn't work
    By JenTDOT in forum Google Pixel & Pixel XL
    Last Post: 11-04-2016, 07:31 PM
  2. Fast charge notification
    By lanric02 in forum Samsung Galaxy S7 edge
    Last Post: 11-04-2016, 07:17 PM
  3. Samsung Galaxy 7 Edge Always On Display
    Last Post: 11-04-2016, 09:52 AM
  4. Replies: 0
    Last Post: 11-03-2016, 10:23 PM
  5. Replies: 0
    Last Post: 11-03-2016, 07:28 PM
