11-12-2016 01:54 AM
132 12345 ...
tools
  1. maccauk's Avatar
    I've registered in UK as well. Finally let me about 2 hrs ago.
    Jamescunni likes this.
    11-09-2016 02:19 PM
  2. LineKill's Avatar
    It's either the 9th November or the 11th September depending on the date format. However, it means the 9th November
    You are correct. I am sorry, I completely read that wrong. Thanks!
    Green Samot likes this.
    11-09-2016 02:20 PM
  3. superstarmc's Avatar
    Register or download the update?
    11-09-2016 02:25 PM
  4. motorcycle_monkey's Avatar
    Finally able to register as well. On Verizon.
    11-09-2016 02:28 PM
  5. Jamescunni's Avatar
    Still not seeing the app on the Galaxy app store in UK got a unlocked device but was previously locked to EE will that mean I'm ineligible on the apk got on the registration page but got server error
    11-09-2016 02:34 PM
  6. mvsmith's Avatar
    I can't wait registered and just waiting for OTA update.
    It does say in the terms you can keep the beta software once nougat hits or upgrade directly to 7.0 release. Hopefully it will be a smoother transition like Nexus beta program.
    On T-Mobile also download the app through Galaxy app store instead of sideloading.
    11-09-2016 02:41 PM
  7. laestrella's Avatar
    I'm on T-Mobile and I registered as well. Now just waiting for the update.
    11-09-2016 02:43 PM
  8. msm0511's Avatar
    Me as well. I almost forgot about it though.
    11-09-2016 02:56 PM
  9. maccauk's Avatar
    I sideloaded app from link on page 1 of this thread. Just kept trying every hour. Not sure if it once being EE only will effect registration.
    11-09-2016 03:02 PM
  10. digital-g's Avatar
    Looks like I'm a day late and a dollar short. Damn!
    Attached Thumbnails Samsung Beta: Nougat Beta available for S7/Edge...kind of-842.jpg
    11-09-2016 05:26 PM
  11. lammy8's Avatar
    Keep getting server error 400 when I try.
    Also it states in the agreement that only unlocked S7 and edges can participate.
    11-09-2016 05:55 PM
  12. Chris Rosas's Avatar
    No tmobile sprint and Verizon will work too. At least that's what the app says once you're done registering.
    But sadly it seems all registrations are full
    11-09-2016 06:02 PM
  13. Jaycemiskel's Avatar
    Man this sucks! I wanted in on the beta but it hit the max. I'm on Verizon.
    11-09-2016 06:39 PM
  14. Jaycemiskel's Avatar
    I was checking earlier today and it wasn't available. Guess I should have just been checking all day long
    11-09-2016 06:40 PM
  15. beri's Avatar
    Hope I got lucky and get in, already registered, just waiting
    11-09-2016 10:12 PM
  16. msndrstood's Avatar
    I'm on Sprint and I registered, no update yet.
    11-09-2016 10:17 PM
  17. japhule's Avatar
    The beta page now shows rollout dates for sprint, vzw and tmo.
    11-09-2016 11:53 PM
  18. aldo82's Avatar
    https://uploads.tapatalk-cdn.com/2016...185784d7bb.jpg
    I installed the update to nougat about 11 pm last night in the UK. Kept checking and it finally popped up! Not much testing yet as mainly been asleep since I got it but it's mote different than iI expected. Lots of changes to settings and notifications in terms of looks. Runs smoothly so far though!
    11-10-2016 12:26 AM
  19. optimummind's Avatar
    Downloading the beta now on my Sprint GS7E. File size is 1521.45 MB for me. Getting excited!
    11-10-2016 01:45 AM
  20. pjwk81's Avatar
    Supposedly it's rolled out last night to all UK phones but I never got the OTA so they must be narrowing it down even between the ones that got registered.
    11-10-2016 01:53 AM
  21. aldo82's Avatar
    Probably obvious but have you tried restarting and checking manually for the update? Worth a try...
    11-10-2016 02:10 AM
  22. aldo82's Avatar
    I can confirm AOD now displays third party notifications and you can double tap to go straight to it. Finally!
    11-10-2016 02:11 AM
  23. beri's Avatar
    How do you get to the faq?
    11-10-2016 02:24 AM
  24. Roman Akert's Avatar
    I'm mostly interested in battery life. At present mine is exceptional.
    Some of the good things that were present in earlier test versions, such as the display white balance adjuster have been culled. No doubt due to manufacturer pressure.
    Not bothered about third party AOD notifications but double tapping to wake would be good rather than constantly having to use a hard button.
    Some more audio settings such as bit rate choice etc would be handy too.
    I guess most of it will be in I'm ally different to MM and what we've already got with TW.
    11-10-2016 02:30 AM
  25. Green Samot's Avatar
    Downloading now in the UK
    Cakefish likes this.
    11-10-2016 03:08 AM
132 12345 ...
  1. Replies: 2
    Last Post: 11-05-2016, 01:00 AM
  2. nougat cat game with v20...
    By Joeykool in forum LG V20
    Last Post: 11-04-2016, 01:26 PM
  3. Replies: 0
    Last Post: 11-04-2016, 10:11 AM
