11-12-2016 01:54 AM
132 ... 23456
tools
  1. Jamescunni's Avatar
    I sideloaded app from link on page 1 of this thread. Just kept trying every hour. Not sure if it once being EE only will effect registration.
    Yeah guessing I'm not eligible tried that already will keep trying though
    11-10-2016 03:12 AM
  2. neil74's Avatar
    How stable is this likely to be?
    I mean Nougat is obviously not beta as it is out there on a number of phones already. It is just the Samsung integration part I guess so how stable can we expect it to be?
    11-10-2016 03:17 AM
  3. aldo82's Avatar
    Seems pretty stable to me from my first few hours of use. Only time will tell longer term of course. I've noticed a few animations stutters occasionally but mostly ok.
    Nougat has been out for many months as developer previews so samsung has had months to get this right. I would expect this is pretty much final release, just running the beta to make sure no major issues.
    neil74, Cakefish and KPMcClave like this.
    11-10-2016 04:17 AM
  4. neil74's Avatar
    This was my view, about to install it...
    11-10-2016 04:28 AM
  5. songbae's Avatar
    Appears that Samsung Pay app isn't supported under Nougat.
    Can anyone else confirm? If so...Samsung Pay for me is the killer app. I'll have to revert if not compatible.
    11-10-2016 04:29 AM
  6. aldo82's Avatar
    Sorry not sure as we don't have Samsung pay in the UK
    11-10-2016 04:41 AM
  7. Cakefish's Avatar
    It's begun
    KPMcClave likes this.
    11-10-2016 05:10 AM
  8. wolverinex's Avatar
    Downloading now for the Sprint network
    11-10-2016 05:14 AM
  9. neil74's Avatar
    Just installed maybe needs to settle down but it feels ever so slightly slower.
    11-10-2016 05:23 AM
  10. aldo82's Avatar
    I feel like it is very similar in terms of speed but with a few lags here and there occasionally. I will have a bit of spare time this weekend so plan to factory reset it then and set up as new as that's generally the best way to handle big OS updates
    11-10-2016 05:29 AM
  11. aldo82's Avatar
    Have to say I'm really liking the double tap of the multitasking button to switch to the last used app. Multitasking seems to be very similar to the nougat implementation
    11-10-2016 05:34 AM
  12. SteveyAsp's Avatar
    Even though you unlock the handset, it'll always be recognised as an EE handset through the software, it's why I used to install the generic software on Samsung's
    11-10-2016 05:48 AM
  13. pjwk81's Avatar
    Has anyone seen a manual download yet? It's obviously not coming to my device but no way I don't want to try this out, even to just make the AOD useful.
    11-10-2016 05:49 AM
  14. kelqwe's Avatar
    I registered in the UK with an unlocked device but I've not seen any sign of the update, maybe I wasn't selected?
    11-10-2016 05:55 AM
  15. rjw's Avatar
    Anyone who has already updated can you let me know if they removed the "Hold" option from Phone screen once a call is placed? I loved how they moved in further into the menus on the Note 7 Grace UI. I hate each time place a call on there is a 50% chance of me putting the call on hold based on how I move the phone to and from my ear.
    11-10-2016 06:25 AM
  16. aldo82's Avatar
    I get these options within a call
    Attached Thumbnails Samsung Beta: Nougat Beta available for S7/Edge...kind of-1078.jpg
    rjw likes this.
    11-10-2016 06:35 AM
  17. rjw's Avatar
    Thanks aldo82. It's gone Thankful... I don't know what Samsung was thinking when they put the option there.
    11-10-2016 06:37 AM
  18. aldo82's Avatar
    I think VOLTE is working on the s7 edge now on EE. I can't find it in the settings but it looks like the phone stays on LTE when making calls. Happy with that!
    In fact just noticed you can see the symbol in the status bar of the voicemail call above
    11-10-2016 06:45 AM
  19. Nakrohtap's Avatar
    I'm kind of mad at myself for not jumping on this sooner. I didn't think it would be that limited in testers.
    11-10-2016 07:57 AM
  20. msndrstood's Avatar
    I got it this morning, on Sprint, manual download. Seems stable so far, snappier, no lag. I haven't dug into it too deep yet. I like the triple tap magnifier. The Notifications panel is cleaner and streamlined. I like it so far.
    mango1228 and Frenzytom like this.
    11-10-2016 08:29 AM
  21. Cakefish's Avatar
    Samsung browser FINALLY has the ability to open tabs in the background. Amazing!
    11-10-2016 10:22 AM
  22. beri's Avatar
    Anyone on Verizon able to download yet?
    11-10-2016 10:28 AM
  23. anon(19981)'s Avatar
    I haven't been able to yet. Been trying every hour or so.
    11-10-2016 10:38 AM
  24. motorcycle_monkey's Avatar
    Per the app, it should start for us tomorrow.
    11-10-2016 10:57 AM
  25. BlkWolf03's Avatar
    It says on the Beta app that Verizon will be able to d/l on 11/11
    11-10-2016 10:57 AM
132 ... 23456
  1. Replies: 2
    Last Post: 11-05-2016, 01:00 AM
  2. nougat cat game with v20...
    By Joeykool in forum LG V20
    Last Post: 11-04-2016, 01:26 PM
  3. Replies: 0
    Last Post: 11-04-2016, 10:11 AM
