11-12-2016 01:54 AM
132 ... 456
tools
  1. ab304945's Avatar
    Also just noticed. The camera software is the same as the note7
    11-11-2016 06:26 PM
  2. LineKill's Avatar
    You have to go into settings>updates and tap on update manually
    Thank you!
    msndrstood likes this.
    11-11-2016 07:52 PM
  3. mrgigabyte's Avatar
    does anyone know if there is a setting for lockscreen that you can have notifications as icons on my note 7 you had that option
    11-11-2016 10:55 PM
  4. anon(27512)'s Avatar
    Anyone know if they will open more slots?
    11-11-2016 11:47 PM
  5. beri's Avatar
    On Verizon here, anyone missing the galaxy apps icon?
    11-12-2016 12:06 AM
  6. mrgigabyte's Avatar
    Yes but I figure it out what you do when your looking at themes you see galaxy app pic press on that and it will ask you what to open it with and then your on app store kind of a pain but that's how to do it
    11-12-2016 12:21 AM
  7. beri's Avatar
    Got it, thanks
    11-12-2016 01:54 AM
132 ... 456
  1. Replies: 2
    Last Post: 11-05-2016, 01:00 AM
  2. nougat cat game with v20...
    By Joeykool in forum LG V20
    Last Post: 11-04-2016, 01:26 PM
  3. Replies: 0
    Last Post: 11-04-2016, 10:11 AM
