1. BlackAudiA5's Avatar
    Just switched over to AT&T from Verizon. Never saw a need for a special "launcher".
    Any recommendations?
    11-05-2016 05:14 PM
  2. Christine Aflak's Avatar
    Nova Launcher Prime is the best. I tried Action Launcher 3 Pro but it is full of bugs and lags like a snail.
    parthtc09 and shaleem like this.
    11-05-2016 05:24 PM
  3. ThrottleJohnny's Avatar
    I'm currently using the new Evie launcher. It's fast and simple. I think it's the best now
    11-05-2016 05:31 PM
  4. BlackAudiA5's Avatar
    Aside from getting "badges" on my gmail icon... why are these launchers such a big deal?
    Do they allow you to MOVE the app access icon in the lower right of the home screen?
    11-05-2016 06:05 PM
  5. chanchan05's Avatar
    Yes and a LOT more. Heck you can remove the dock and access the app drawer via gesture. You can change grids, change the icon of individual apps, the limit is so high. Check this link to see what other people have done with their launchers:
    http://androidforums.com/index.php?threads/4425/
    11-05-2016 06:58 PM
  6. Dimas de Leon's Avatar
    Nova Prime is the best, you can even place widgets in the dock, I have my volume widget and brightness widget there. Launchers?-capture-_2016-11-05-22-58-19.jpg
    11-06-2016 01:00 AM
  7. bandofbrothers2112's Avatar
    Being new to android and using the s7 edge I've looked at launchers.
    Nova does look impressive.
    But for now TouchWizz and the SB Theme I've downloaded fulfills my needs.
    11-06-2016 02:46 AM
  8. 420lyfe's Avatar
    Z launcher is my personal choice for a launcher. I think it's by far the best launcher for me and I have many friends that I was able to introduce it too and they seem to enjoy it too. Majority of the people I know are now using it because it's smooth and way too good. Almost flawless when it comes to usage... bug free and that's a guarantee ... I also enjoy zen launcher but it's not as good and I don't really ever use it. Z launcher by Nokia is probably the best out there for me. Feel free to give it a try.
    11-06-2016 03:33 AM
  9. Johnston212's Avatar
    I have really enjoyed Next 3D launcher, but I am surprised to find that I am enjoying TouchWiz at the moment.
    11-06-2016 06:00 AM
  10. patcal's Avatar
    Long time Apex user. Might try Nova though.
    11-06-2016 07:08 AM
  11. Ipse_Tase's Avatar
    Another vote for Nova (prime or not). Been using it for 4+ years now.
    Get a set of icons to match your preferences and it's like a different phone.
    11-06-2016 08:43 AM
  12. shaleem's Avatar
    For me, it is Nova Launcher Prime.
    11-06-2016 09:09 AM
  13. BlackAudiA5's Avatar
    Well I downloaded and installed Nova (free) launcher and set it all up.
    Pretty cool, but now I don't have ANY badges illustrating how many notifications I have for each app. I guess I've gotten used to this with the stock launcher from Motorola/Verizon.
    I've heard Nova PRO does this. If I switch to a different launcher, will I have to rearrange all my icons again?
    11-06-2016 09:45 AM
  14. chanchan05's Avatar
    Yes. You'll have to rearrange.
    The Tesla Unread Plugin (which gives you the badges for Nova) only work with the Prime version.
    11-06-2016 10:05 AM
  15. Roman Akert's Avatar
    TW. Fast and easy on the battery.
    11-06-2016 10:17 AM
  16. BlackAudiA5's Avatar
    Spent the money for Nova PRO. Now I have the badges. THANKS!
    11-06-2016 10:54 AM
  17. sj jain's Avatar
    Launcher drain so much of battery so I will advise you to stay with original launcher of your device but if you Still want another launcher you can use Nova launcher or others
    11-06-2016 11:53 AM
  18. o4liberty's Avatar
    Google launcher works well for me
    11-06-2016 12:29 PM
  19. kabeeo's Avatar
    I was a Go Launcher guy for ages then went to Nova Launcher Prime on my Note 5. Now that I'm on the 7 Edge (via Note 7 sadly) I am trying to give Touch Wiz a chance. So far I'm finding it to be OK.
    11-06-2016 12:49 PM
  20. aldo82's Avatar
    I use action launcher and am very happy with it. Some great useful features compared to other launchers and we'll supported by the developer on the beta program
    11-06-2016 01:34 PM
  1. Nova Launcher and V20
    By Brian Gottschalk in forum LG V20
    Last Post: 04-18-2017, 11:28 AM
  2. Nova Launcher on Honor 8
    By ChumsFuture in forum Honor 8
    Last Post: 11-04-2016, 01:40 PM
  3. What android launcher do my phone needs
    Last Post: 11-01-2016, 12:05 PM
  4. Google Pixel Launcher
    By stmiranda in forum Samsung Galaxy S6
    Last Post: 11-01-2016, 12:19 AM
  5. Action Launcher
    By Robin Hebert in forum Google Pixel & Pixel XL
    Last Post: 10-29-2016, 01:26 PM
