1. venom0706's Avatar
    So, I downloaded an MP4 clip on my S7 Edge for the first time. When I go to MyFiles and access the clip from there, it asks me what player I want to open it with, but only for the first time. After that, whenever I play the clip, it opens it with that player I have chosen. Is this normal? Do you know how I can change the player every time I open a video (except going to the player app and open it from there. I am talking specifically for the MyFiles app).
    Thank you and appreciated.
    11-06-2016 04:52 PM
  2. amyf27's Avatar
    I just use the default one at least for now
    11-06-2016 05:53 PM
  3. French's Avatar
    Settings>Applications>Default app setting, change to "ask before setting default" . This should result in you choosing which app opens each time.
    Kiet189 likes this.
    11-06-2016 06:00 PM
  4. Kathy Shaw's Avatar
    I know that the Samsung manufacturer has removed both its stock music and video player applications from the units and instead, replaced them with Google Play music and Google Play Movie, which only allow you to play Google Play store purchased or rented music or movies. Which default media player you are using?
    02-10-2017 01:45 AM
  5. paridge's Avatar
    You can play anything on your device. You're not limited to Play Store content.
    02-25-2017 01:43 PM
  1. how can i find the call history of a particular contact note4
    Last Post: 11-08-2016, 05:39 AM
  2. Moving apps to SD card GT-s6810p
    Last Post: 11-06-2016, 05:36 PM
  3. got andriod lg4 phone wont turn on want to hook to pc
    Last Post: 11-06-2016, 05:35 PM
  4. Replies: 1
    Last Post: 11-06-2016, 03:45 PM
  5. Replies: 1
    Last Post: 11-06-2016, 03:38 PM
