I haven't been using it either really. I just put common things on my home pages including some Web pages. I'm not crazy about the edge thing but it looks nice.I never use the edge part of the screen, am I the only one . How do you all put use to it?
I don't use it, I have it completely disabled, I didn't buy the phone for that feature, if asked, I bought it for the larger screen and battery
I think you will love itThanks for sharing, Going to download softkey edge now, so over the two button deal.
I thank you for that info as well. I can never get the two button method to work so I use the Palm swipe and sometimes that can be a job if you are trying to cap a scrolling screen.I think you will love it
I agree, you only want 3 or 4 edge screens at most, or you lose the benefit of speed of doing something. And that is the biggest benefit of edge, plus like you said, you can be doing something on your phone, slide the edge select textra, send a text and when done your right back to what you were doing, it's nice not having to close out of what you were doing then come back and open it again.I most frequently use the Edge panel for Apps. I'm a heavy user of my phone for work so I'm in and out of Todoist, the BlackBerry Hub for Android, and Excel. So, I love the fact that I can use the edge to quickly and unobtrusively open apps like Contacts, Calendar, calculator, Facebook, Feedly and Textra without having to leave the app and go back to the home screen.
Initially, i was not a believer in the Edge panel... I bought the phone for the battery (which I love!) and large screen... While maintaining reasonable accessibility with 1 hand.
However, loading up a bunch of panels doesn't seem like much of a time-saver to me... I only use Apps, Contacts, and the Calendar widget.
Hope that gives you a better perspective.
