MTP mode
cassar82
Active member
Oct 23, 2016
38
How do I set my s7 edge in MTP mode? I'm trying to connect to Kies3 but I need to set MTP mode please help I'm gonna be using a PC & Mac
Tim1954
Q&A Team
Jan 17, 2016
6,924
Once you connect your device, pull down the quick settings menu and tap on the usb notification. The modes will be there
chanchan05
Q&A Team
Nov 22, 2014
8,519
You need to be using a USB cable that supports data transmission. Are you using the supplied cable?
When you pull down the notification bar, tap on the notification that says charging
fallingOutOfLoveWfithTech
