12-19-2018 07:49 PM
36 12
tools
  1. Galaxy s7 edge's Avatar
    I got my s7 edge 1 week ago and 2 days ago it started draining battery after an updateAndroid system is draining battery-1478540394379.jpgAndroid system is draining battery-1478540401487.jpg
    11-07-2016 12:40 PM
  2. Rukbat's Avatar
    Restart in recovery mode (from power off - Volume up+home+power until the phone starts) and clear the cache. (You won't lose any data.)
    A new update will drain more battery, because some of the changes were made after the update was written, so it's downloading a lot of data.
    11-07-2016 01:05 PM
  3. Galaxy s7 edge's Avatar
    I have done this multiple times and the update was done about 2 days ago
    11-07-2016 01:31 PM
  4. hishaq96's Avatar
    I'm getting Really poor battery life for a £640 phone. I have cleared the cache many times still i never see the difference. Is there any other way I could get better battery?Android system is draining battery-1478556407825.jpgAndroid system is draining battery-1478556415347.jpgAndroid system is draining battery-1478556420207.jpg
    11-07-2016 05:07 PM
  5. Galaxy s7 edge's Avatar
    Seems like me and you have the same proble
    11-07-2016 05:52 PM
  6. Galaxy s7 edge's Avatar
    Did this happen to you after an update?
    11-07-2016 05:53 PM
  7. hishaq96's Avatar
    Yes it's got worse after the update but before that it was also not so good
    11-07-2016 07:05 PM
  8. Galaxy s7 edge's Avatar
    Man I used to get 6 hours screen on time and know I struggle to even get 2
    11-07-2016 07:22 PM
  9. hishaq96's Avatar
    This phone turning into as worse as s6
    11-07-2016 07:38 PM
  10. hishaq96's Avatar
    I still don't know how people get over 6hrs sot all the time
    11-07-2016 07:40 PM
  11. ThrottleJohnny's Avatar
    My battery life on the S7 Edge is still amazing.
    I'm not sure what you guys are doing differently with your phones
    11-07-2016 08:45 PM
  12. Galaxy s7 edge's Avatar
    Maybe a factor reset after and update should solve the problem
    11-07-2016 10:27 PM
  13. Galaxy s7 edge's Avatar
    Just performed a factor reset I let you know if it fixed the issue
    11-07-2016 11:37 PM
  14. Snareman's Avatar
    I"m getting a ton of battery drain from the OS as well. I used to end my 10h shifts in the ER around 60% on all my previous phones (N7 included). was in the 50's with the 7E and now finish the day in the low 40's. OS drain was 34% today. Not sure what it should be.
    11-08-2016 12:33 AM
  15. hishaq96's Avatar
    I've also done the factory reset many times it still doesn't seem to change anything
    11-08-2016 02:14 AM
  16. Nodnerb's Avatar
    Mine was like that. Sometimes 50% or more battery was android system. Always the top of the list and at least 40% usage. Turning off "keep wifi on during sleep" dropped it down to 15%-ish consistently for the past several months.
    11-08-2016 08:50 AM
  17. Galaxy s7 edge's Avatar
    After a factor reset and some tweaking
    Android system is draining battery-1478618347011.jpgAndroid system is draining battery-1478618351102.jpg
    11-08-2016 10:19 AM
  18. Tsepz_GP's Avatar
    To everyone experiencing Android System Battery Drain I have some questions:
    Are you using Package Disabler (PD) with Admin rights?
    What have you disabled with Package Disabler?
    I ask all this as I used PD for a day in my S7 Edge and Disabled all Gear VR services, and that had my Android System up and draining a bit of battery, it even caused some instability, at some point the phone didn't want to Wake Up and I had to force reboot the phone, I then reenabled the stuff I'd ticked in PD and uninstalled PD and my phone went back to normal.
    11-08-2016 12:14 PM
  19. Galaxy s7 edge's Avatar
    I use PD and remove all bloat
    11-08-2016 12:28 PM
  20. Tsepz_GP's Avatar
    I get the feeling PD is causing problems. Remember that the 'Bloat' is part of Samsung's entire system, it seems that when we 'force Disable' it with PD it causes a ripple effect, and messes with other processes.
    I may be wrong though, but I am staying clear of PD for now.
    11-08-2016 12:31 PM
  21. Galaxy s7 edge's Avatar
    I'll test it for a few days I let you in on what I get
    11-08-2016 12:33 PM
  22. ThrottleJohnny's Avatar
    I agree. A lot of times the very thing people use to monitor their devices, is the thing that is going rouge in their phones. I don't use any of that stuff and my battery life kicks ***
    11-08-2016 01:14 PM
  23. Galaxy s7 edge's Avatar
    Here's an update my battery kicking *** I would sayAndroid system is draining battery-1478634002744.jpgAndroid system is draining battery-1478634007674.jpg
    11-08-2016 02:40 PM
  24. Galaxy s7 edge's Avatar
    11-08-2016 05:45 PM
  25. popkurn611's Avatar
    So what was the given culprit??
    11-08-2016 08:48 PM
36 12
  1. Is anyone using the new Google Assistant?
    By DWooderson in forum Google Nexus 6
    Last Post: 12-11-2016, 02:49 AM
  2. New version of Android Auto version 2.0.642304-release
    By Andrew DeFaria in forum Android Auto
    Last Post: 11-13-2016, 08:41 PM
  3. Replies: 7
    Last Post: 11-07-2016, 08:46 PM
  4. My galaxy s7 edge android system battery drain
    By Galaxy s7 edge in forum Ask a Question
    Last Post: 11-07-2016, 01:06 PM
  5. Why LG Stylo2 wont connect to Android Auto
    Last Post: 11-07-2016, 11:54 AM
