1. Yaseensaadz's Avatar
    Works on one side for both the bluetooth headphones and the wired headphones , so i guess its not a problem with the headphone jack right ? My phone is galaxy s7 edge . Already tried going to mono settings its set in the middle between left and right . Please help what should i do? Dont have a warranty . It used to work phine i was listinning to music with the bluetooth headset and then switched to wired one while the song was playing and after that the problem occured
    Safe mode didn't work too
    Tried resetting settings . Now bluetooth works fine
    11-09-2016 10:17 PM
  2. chanchan05's Avatar
    Run the phone in safe mode. If it works properly, then you have an app messing with it.
    11-09-2016 10:19 PM
  3. Yaseensaadz's Avatar
    Nope . Didn't work in safe mode too
    11-09-2016 10:27 PM
  4. japhule's Avatar
    Go to Accessibility > Hearing and make sure mono audio is not enabled.
    11-09-2016 11:02 PM
  5. tastyprawns's Avatar
    i didn't understand what you said.
    you tried multiple phones right?
    you restarted the phone?
    did you do a factory reset?
    11-10-2016 12:41 AM
  1. How do i get my BLU out of factory mode?
    Last Post: 09-26-2017, 02:17 AM
  2. What are my options for bundle package/ phone cable internet
    Last Post: 11-10-2016, 06:51 AM
  3. Why won't my battery charge.
    Last Post: 11-10-2016, 05:39 AM
  4. How can i delete a comment i posted on a website?
    Last Post: 11-10-2016, 04:29 AM
  5. Thoughts on switching to T-mobile with the 6p
    By angelbones1 in forum Nexus 6P
    Last Post: 11-09-2016, 10:39 PM
