12-31-2016 02:53 PM
584 ... 1415161718 ...
tools
  1. pjwk81's Avatar
    it says right on the download info that the beta is not compatible with the Gear. You'll either have to wait for the official or roll back to 6 if this is a deal breaker for you. This is the beta just released [I am on Sprint if that might make a difference].
    You're thinking of the VR only (I meant watch, should have said Gear S) and the third beta added the functionality again.
    KPMcClave likes this.
    12-01-2016 11:10 PM
  2. MalachyNG's Avatar
    I've had beta3 and appreciate the resizing options in the quick settings and being able to have the brightness slider on the first notification shade again.
    I've gotten the system UI stopped error once. hasn't happened since.
    Did a day with Normal performance setting with highest screen resolution. also did a day with performance mode on - I don't like the persistent icon for it. I get that they don't want you using it all the time but I also didn't see that much of a battery hit from keeping it on all day. Next I'll check out normal with 1080p resolution just to see if that really does anything. Mostly Ive been getting 3-4h screen on time - about the same as on marshmallow.
    One thing that really bothered me when I first installed the beta was it defaulted to zoomed in display scaling and that really F'ed up my google now launcher where all but a handful of my icons remained and pretty much all of a my widgets were removed. And I didn't quite remember where everything had previously been but damned if I had a couple of days of annoyance due to muscle memory of where things ought to be but no recollection of which specific apps belonged where until I had a need to use it and it wasn't in its usual place.
    So far nougat is pretty stable and I am digging it. Brought some new life to my phone.
    AOD is so much better - I didn't even AOD for the first 6 months of owning the phone since it was pretty useless to me. Before the nougat beta I tried it out for a day or 2 with the limited update it got but with 3rd party notifications and being able to double tap an icon to wake up the phone has made it very useful. Should have been like that from the start!
    Nakrohtap and KPMcClave like this.
    12-01-2016 11:11 PM
  3. Roman Akert's Avatar
    Seems to me Nougat is largely a wasted opportunity.
    There seems to be very little new, much of it being small changes in looks, not all good.
    Still not a fully featured AOD, no new audio settings, no apparent improvement in battery performance, no new screen White Balance adjustment (removed). They have given us a call screen that changes colour ... erm, yes.
    All in all this seems disappointingly thinly featured for a new OS. I like to think that more effort has been spent on underlying security. Perhaps they made it easier for manufacturers to embed crxxxware which we can't get rid of?
    Awaiting the final release but I am certainly not in a rush to change on the basis of what I've seen.
    12-02-2016 12:15 AM
  4. maclancer's Avatar
    What about the seamless update to new versions of Android similar to Chrome. Well, to be fair, they said that this feature will be only on smartphones that shipped with Nougat.
    12-02-2016 12:19 AM
  5. pjwk81's Avatar
    What's wrong with the AOD? I haven't noticed anything missing now.
    12-02-2016 12:24 AM
  6. chanchan05's Avatar
    Because Nougat is more of an under the hood update than a looks update. Not everything that's changed has to be visible.
    12-02-2016 12:27 AM
  7. maclancer's Avatar
    I think the main feature of Nougat is the ability to upgrade to new versions of Android. However, they said that this will only apply to phones that shipped with Nougat. So basically for us that upgrade to Nougat is going to be just another Marshmallow.
    12-02-2016 12:34 AM
  8. ThrottleJohnny's Avatar
    I like the under the hood changes. Smoother transitions, better battery life, closer to stock, and everything from notifications, settings, keyboard to AOD feels new and improved.
    It'll be tough to ever go back to MM.
    12-02-2016 12:57 AM
  9. kbennett65's Avatar
    It hasn't been reopened for Verizon apparently yet.
    Sorry about that. Didn't realize the update wasn't working for Verizon
    12-02-2016 01:28 AM
  10. kbennett65's Avatar
    Yep. That's exactly what I was thinking. I have the Gear VR so that was on my mind. I decided I don't use it so much that I couldn't live without it until the official release.
    Kind of surprises me the Samsung Gear watch didn't work with the Samsung phone out of the gate.
    12-02-2016 01:33 AM
  11. pjwk81's Avatar
    I only ever used my Gear VR twice (it came with the phone) before selling it.
    I think the Gear S/2/3 work fine, I was just worried maybe they had left it out of the initial beta but all seems good with it.
    12-02-2016 01:48 AM
  12. aldo82's Avatar
    There are way more changes to Samsung's nougat than I expected. Everything has had a visual refresh and if you use a different launcher, it would be hard pressed to tell its the same phone by just looking at the interface.
    Notifications, quick settings and the settings menu have all changed. Samsung apps have had a refresh. Aod now supports third party apps. Battery life is slightly better. It's a 100% win as far as I'm concerned
    12-02-2016 02:57 AM
  13. engineeryajeeb's Avatar
    Has anyone also experience playing videos under My Files app? It seem to crash when playing from there. Another bug maybe
    12-02-2016 04:27 AM
  14. Nakrohtap's Avatar
    Thanks for pointing out the brightness slider. I did not know they added that option.
    Is there a log for beta changes? I remember seeing posts where people posted some changes. It's not in the app. I get server error messages at the moment.
    12-02-2016 05:31 AM
  15. Nakrohtap's Avatar
    I just played a video through My Files with no issue. Maybe it's the video player and not the My Files app?
    12-02-2016 05:33 AM
  16. jejb's Avatar
    I'm in no hurry to get Nougat. I came from a Nexus 6P recently to the S7E, and the 6P forums are full of threads about much worse battery life than MM (I stayed on MM with mine). I don't see any of the things Nougat brings as making my Android experience any more satisfying, personally. I hope that once they release the official version on my phone, that most of the bugs will be worked out. My battery life is outstanding on my S7E. I'd be upset if they messed that up in a rush to get different looking icons.
    12-02-2016 06:23 AM
  17. beri's Avatar
    Apparently Samsung is now working with Verizon with the updates. This blows for us! We'll get update 3 when everyone else is on 5.
    12-02-2016 07:27 AM
  18. KPMcClave's Avatar
    I have an S2 and it did work out of the gate.
    12-02-2016 07:40 AM
  19. KPMcClave's Avatar
    Samsung must've left something in that Verizon can monetize. Because my expereince with the first 2 Betas has been very good.
    12-02-2016 07:42 AM
  20. beri's Avatar
    Now I notice, again on Verizon, whenever I go into the Beta app I get the option to register. Previously when is go into the app I got the option to deregister. Kinda weird...
    12-02-2016 03:54 PM
  21. jrcdpm's Avatar
    You can get into the Beta app. I just get the server error message.
    12-02-2016 04:11 PM
  22. kbennett65's Avatar
    I have been using the beta since yesterday and first impression is pretty good. I have some "lag" opening a few things, particularly the app manager seems slow to respond. I actually prefer the old version of always on as the night clock on the edge would show the alarm time I had set while this update shows the date instead. As far as I can tell there is no way change what appears on this. An option to choose what information is shown on the night clock beyond just choosing right or left edge would be nice.
    The only compatibility issue I have run across is with my preferred Go products: I use Go Launcher which is working fine, some of the transitions options aren't there anymore but that is certainly not a big deal. I have experienced no problems [yet] with GoSMS which is good as I use that for my default messenger.
    Go Locker is working fine, though it's a good thing I had my lock screen security set to none because the option to change that won't work as my phone refuses to recognize my fingerprint and I have no earthly clue what my back up password is. If anybody has a clue how to recover it please let me know!
    Go Weather was working fine until I installed an update lat night, now the widget won't load, I get a "GoWeather unexpected error" notification every time. As I figure this is a Go Weather issue after their update I have contacted the developer to make them aware of the problem.
    12-02-2016 04:12 PM
  23. Aquila's Avatar
    This is a very poor list of the actual features of Nougat. Here's a short list of the improvements:
    Seamless updates
    Better security (Major upgrade here on multiple fronts, including file based encryption and directboot)
    UI improvements
    Much better battery life
    DayDream (for devices that meet minimum qualifications)
    Improvements to multi-tasking, including native split screen
    Drag & Drop Text + Major improvements to the ability to add content through the keyboard
    Improved notifications (UI)
    Quick replies from notifications
    Notification controls
    Better Quick Settings
    Major improvements to settings UI
    Better data saver controls
    Major improvements to accessibility features
    Improved keyboard, including more functionality for multiple languages
    Display customization options
    Device migration improvements and major improvements to Android Backup
    Huge improvements to JIT and ART
    Think I ran out of the most obvious things, but most of it was under the hood, makings either easier, faster, smoother or more intuitive through UI cues, etc.
    Or did I misunderstand and you're saying that Samsung's version of Nougat isn't up to par, rather than Nougat itself?
    thecomicbookandme likes this.
    12-02-2016 04:28 PM
  24. jackjack1969's Avatar
    Don't know if anyone what mentioned this. I just got the beta a couple days ago. Since then when my alarm goes off in the morning, the screen doesn't wake up. When I wake the screen up, it is like hitting the snooze button. It takes me 30 minutes to finally get it to quit
    12-02-2016 05:06 PM
  25. Nakrohtap's Avatar
    My alarm was left alone after the update and it still works and looks mostly the same. After I hit the snooze, the screen lights up for a few seconds, then shuts off.
    12-02-2016 05:17 PM
  1. Rooted my Galaxy S7... now it's trash
    By EasyOver in forum Samsung Galaxy S7 Rooting, ROMs, & Hacks
    Last Post: 11-26-2016, 03:37 AM
  2. Screen Unresponsive S7 Edge
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 11-10-2016, 05:55 PM
  3. Rooted my Galaxy S7... now it's trash
    Last Post: 11-10-2016, 05:08 PM
  4. Screen Unresponsive S7 Edge
    Last Post: 11-10-2016, 01:27 PM
  5. Replies: 0
    Last Post: 11-10-2016, 12:28 PM
