CNN doesn't work for me eitherAnyone elses CNN app keep crashing?
The battery drain while WiFi is turned on is truly terrible. Easily the worst aspect of the beta. Battery life with WiFi off is decent, but as soon as you turn wifi on it goes down the drain. Even in safe mode so 3rd party apps aren't the culprit.
Got the beta last night (Sprint). After a full day of using it heavily and trying to test it to the best of my ability, I have yet to encounter a single glitch! Not a single one of the issues that I have read about has happened. No battery issues (on WI-FI or otherwise), no issues with the blue light filter, no issues adjusting the resolution scaling, no app conflicts, no notification issues (it's even working perfect with my Asus Zen Watch 2). I'm thinking that maybe the build that those of us are just getting now after they reopened the beta program is an updated build.
Why the discrepancy? I've recently factory reset my phone.I'm getting phenomenal battery life so far.
8h of SOT? You must be at very low brightness or probably not counting correctly, because my S7 does not give me anymore than 5-6h on avg brightness and usage. You really must be using something or possibly turning the brightness low in order to achieve such good SOT. Battery life is great on the s7 no complaints but at the same time it's good to know that it can last longer if you manage it.
I keep my brightness at about 50% and get an average of 2-3 hrs over 1-2 days standby. I consider that normal for my usage as I get the same stats on two S7 Edge phones AND a Note 5. I have the US version so the person above having the Exynos version, their usage is entirely possible.
I can't stand the brightness any lower then 50%.
I would not have any use for the S7e if I'd get your SOT.
