12-31-2016 02:53 PM
584 ... 21222324
tools
  1. hishaq96's Avatar
    Looks like battery gone worse than before s7 edge 7.0 beta thread-1482861126639.jpgs7 edge 7.0 beta thread-1482861130670.jpg
    12-27-2016 11:52 AM
  2. aldo82's Avatar
    My battery life seems to be pretty good on beta 5. Certainly no worse
    12-28-2016 11:44 AM
  3. chrgnthru's Avatar
    Can anyone point me on where I can find info on reverting back to T-Mobile "stock" firmware? I gotta exchange the wife's S7 edge for a new one on friday. I've tried googling but I can't seem to find anything concrete.
    12-28-2016 10:19 PM
  4. djepperson1's Avatar
    You can use smart switch on a pc the first time you connect the phone it will prompt if you want to download and install official firmware
    12-28-2016 11:36 PM
  5. smooches680's Avatar
    I'm in the USA in Georgia just received my update!!
    12-29-2016 01:10 AM
  6. NexusGirlX's Avatar
    New update for T-Mobile also.
    12-29-2016 01:12 AM
  7. amyf27's Avatar
    Dumb question how do you get it do you just check phone for updates?
    12-29-2016 04:12 AM
  8. amyf27's Avatar
    Where do you get it. I'm on tmobile and when I check for updates it's not there
    12-29-2016 04:13 AM
  9. tonyron227's Avatar
    Check again. I'm on T-Mobile and it is live...
    12-29-2016 04:16 AM
  10. amyf27's Avatar
    Says mine is up to date.
    12-29-2016 04:36 AM
  11. erasat's Avatar
    According to their instructions you must opt-out of the beta first, then go to Smart Switch and download the official Marshmallow firmware.
    12-29-2016 07:18 AM
  12. Nakrohtap's Avatar
    Maybe a dumb question, but why do you need to revert back to MM? Did they tell you to do this? You didn't mention what the issue is with her phone. It's not like you rooted it and put third party OS on it.
    The reason you cannot find any info on doing this is because it's probably not necessary.
    Just do a factory reset and call it a day.
    If T-mobile plans to do anything else with this phone, I am sure they have the tools to revert the software on it.
    12-29-2016 10:37 AM
  13. NexusGirlX's Avatar
    I just checked for updates last night when I got home and it was there. You are on the Nougat beta already, right?
    12-29-2016 01:38 PM
  14. amyf27's Avatar
    No I tried to get that and it said they already had the beta applicants.
    12-29-2016 01:39 PM
  15. NexusGirlX's Avatar
    Your out lf luck then. You had to download the Samsung Beta app, open it and apply. Once you were approved, you just checked for updates and the Nougat beta would download and upgrade. That ended in the middle of December.
    12-29-2016 01:42 PM
  16. Nakrohtap's Avatar
    Well...this IS the Nougat beta thread.
    I am sure it was assumed you were on beta.
    12-29-2016 04:35 PM
  17. jamezr's Avatar
    Got the new beta last night.Battery life has been great on this one. Lovin my S7 edge more and more on Nougat.....
    12-29-2016 04:48 PM
  18. ThrottleJohnny's Avatar
    Anyone know how you close recent apps now?
    Edit: Nevermind. My screen froze so I had to restart.
    12-29-2016 05:32 PM
  19. NexusGirlX's Avatar
    Hit the recent apps button to the left of the home button and then tap close all or hit the x on any app or swipe to the left or right in that list. It's that simple.
    12-29-2016 05:34 PM
  20. ThrottleJohnny's Avatar
    Hit the recent apps button to the left of the home button and then tap close all. It's that simple.
    Thanks. It was an issue with my screen.
    12-29-2016 05:35 PM
  21. NexusGirlX's Avatar
    I edited my post above to add more to it. Was hoping I got it in before you replied but anyways...
    12-29-2016 05:43 PM
  22. ThrottleJohnny's Avatar
    Battery is great with this last update. It's been the buggiest with my phone however. : /
    12-29-2016 05:50 PM
  23. smooches680's Avatar
    I just checked for updates manually.
    12-29-2016 09:37 PM
  24. chrgnthru's Avatar
    Well, last time I had a issue with a phone (iPhone) I was on the beta and the employees at my local store said they couldn't touch it until I removed the beta software. So I rather just go back to stock in order to avoid any annoyance. As far as the problem with the phone it's been super laggy random reboots (even before Beta software) and now she's getting a "camera failed" message when she tries to access the camera.
    12-29-2016 10:43 PM
  25. pjwk81's Avatar
    No more releases.
    anon(9408097) and jamezr like this.
    12-30-2016 12:53 AM
584 ... 21222324
  1. Rooted my Galaxy S7... now it's trash
    By EasyOver in forum Samsung Galaxy S7 Rooting, ROMs, & Hacks
    Last Post: 11-26-2016, 03:37 AM
  2. Screen Unresponsive S7 Edge
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 11-10-2016, 05:55 PM
  3. Rooted my Galaxy S7... now it's trash
    Last Post: 11-10-2016, 05:08 PM
  4. Screen Unresponsive S7 Edge
    Last Post: 11-10-2016, 01:27 PM
  5. Replies: 0
    Last Post: 11-10-2016, 12:28 PM
