12-31-2016 02:53 PM
584 ... 23456 ...
tools
  1. ab304945's Avatar
    Did anyone else's take forever to download? I'm on WiFi and a very fast WiFi and it is taking forever. I'm at 70% and it has been downloading for about 15 minutes or so now
    Ya it took me a while for it to download
    11-11-2016 03:10 PM
  2. ab304945's Avatar
    My phone got very warm while upgrading to nougat while wireless charging. Watch out for that.
    Mine got very warm to
    11-11-2016 03:10 PM
  3. Maxwell Weinbach's Avatar
    Did anyone get a notification saying that they were accepted into the program, or did it just say there was an OTA update and download the nougat beta. I am on T-Mobile and wondering if I was accepted or if I on not getting it. I am qualified for it and really want to get it. Anybody know about it.
    11-11-2016 03:13 PM
  4. amyf27's Avatar
    When I tried yesterday I got a message stating they reached their allowable amount of people so basically it's not offered anymore, just to a specific amount of people
    11-11-2016 03:17 PM
  5. japhule's Avatar
    I was never notified. After registering the other day, I just kept on checking for system updates throughout the day until it was available. If you were able to successfully register, just keep checking on the date of availability.
    KPMcClave and smooches680 like this.
    11-11-2016 03:22 PM
  6. JDGAFFLIN's Avatar
    I think that was one of the prerequisites for the Beta that the VR wouldn't work. I've a Gear S3 arriving next week and hopefully it's ok.
    Ahh, I missed that initially. Thanks!
    11-11-2016 03:29 PM
  7. optimummind's Avatar
    Yep, I just went and checked the thread where I thought I'd seen it and the first Sprint post was from 2:45 AM ET on the 10th. So, I guess it's true unless he's on the West Coast.
    I think that was me. I got my beta update on the 9th. I'm in California.
    KPMcClave likes this.
    11-11-2016 04:15 PM
  8. alarsen7's Avatar
    Does anyone know if the battery section if the settings menu is still there?
    11-11-2016 04:51 PM
  9. WingLT's Avatar
    So how long do the rest of us have to wait for this to become available fully? I was trying to register several times and always got the error. Then a message saying that they were maxed limit. It's totally stupid.
    hailsusy90 likes this.
    11-11-2016 06:31 PM
  10. Premium1's Avatar
    Just worried it can cause issues since it's not available for download as an official update. You guys aren't concerned?
    Well it is a beta, hence being pushed by samsung to try and get any bugs ironed out before the full release.
    11-11-2016 06:44 PM
  11. maccauk's Avatar
    Mid to late December according to the beta notes. It's not that long really. I got it on o2 in the UK yesterday. But believe me it's worth the wait. I had to give up my note 7 for an s7 edge. Now my edge feels as good if not better than note 7. It's a mega update. You will not be disappointed.
    11-11-2016 06:55 PM
  12. alarsen7's Avatar
    So I have the beta and when I go into the beta app I don't have any options to send feedback. Anyone else having this issue?
    11-11-2016 06:57 PM
  13. LineKill's Avatar
    There should be an app on your phone now called "Samsung Members". This is where you can send your feedback among other things.
    11-11-2016 07:50 PM
  14. alarsen7's Avatar
    Ah ok thank you.
    11-11-2016 09:43 PM
  15. erictrinh276's Avatar
    Nope. Its gone. But u can long press on the Power Saving toggle to go to the battery settings
    11-11-2016 10:07 PM
  16. erictrinh276's Avatar
    I couldn't get Good Lock to work at all. You can edit the notification area though. If you fully expand it there's 3 dots beside the settings gear icon top-right that will let you move then around.
    I have Sprint version and cant find the data toggle anywhere
    11-11-2016 10:15 PM
  17. mrgigabyte's Avatar
    does anyone know if there is a setting for lockscreen that you can have notifications as icons on my note 7 you had that option
    11-11-2016 10:52 PM
  18. ajaffarali's Avatar
    Has Samsung changed screen sensitivity settings? I found the S7 to be too sensitive but the Note 7 was perfect.
    11-12-2016 01:26 AM
  19. bandofbrothers2112's Avatar
    I'm loving the update so far, its taking a while to get used to the new settings menu but I'm sure it'll become easier soon. Has anyone used android pay yet? I tried this morning in my usual shop before work and it wasn't picked up at all by the card reader. I've checked the pay app and all the settings I can think of and they all look correct.
    Also the out and about feature is gone? I really liked this for setting things like mute and WiFi off at work, wifi on when I got home. Was this a feature on the note? I'd really like to have it back.
    Out and About feature....
    I've not seen that setting on my s7 edge?
    11-12-2016 03:56 AM
  20. chanchan05's Avatar
    It's one of the Edge Panels.
    bandofbrothers2112 likes this.
    11-12-2016 04:07 AM
  21. aldo82's Avatar
    Anyone got facebook working after doing a factory reset? It worked ok when I updated to nougat but after a factory reset and fresh install of apps it just force closes now and won't open at all
    11-12-2016 04:13 AM
  22. Cakefish's Avatar
    It's categorised under the "device maintenance" section.
    11-12-2016 06:26 AM
  23. LineKill's Avatar
    I did a factory reset and Facebook is working without issue.
    11-12-2016 06:34 AM
  24. Nakrohtap's Avatar
    I think most of us are "disappointed" because we couldn't get on the Beta train and are reading how great this update is. Coming from the Note7, I'm sure it's a huge improvement in the S7E to close the gap. The fact that the Beta program was so limited in its participation and this information was not known at the onset is the irritating part.
    One question on the update...did they find a way to incorporate gif maker without the s-pen?
    11-12-2016 07:01 AM
  25. aldo82's Avatar
    Interesting. Does your version come with facebook already installed or did you install it from the play store?
    Anyway if it happens to anyone else I found the solution in the beta feedback forum. You have to go into settings and accounts on the phone and add the facebook account there, before opening the facebook app for the first time. Then it works fine
    11-12-2016 07:54 AM
584 ... 23456 ...
  1. Rooted my Galaxy S7... now it's trash
    By EasyOver in forum Samsung Galaxy S7 Rooting, ROMs, & Hacks
    Last Post: 11-26-2016, 03:37 AM
  2. Screen Unresponsive S7 Edge
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 11-10-2016, 05:55 PM
  3. Rooted my Galaxy S7... now it's trash
    Last Post: 11-10-2016, 05:08 PM
  4. Screen Unresponsive S7 Edge
    Last Post: 11-10-2016, 01:27 PM
  5. Replies: 0
    Last Post: 11-10-2016, 12:28 PM
