12-31-2016 02:53 PM
584 ... 45678 ...
tools
  1. KPMcClave's Avatar
    No its not. We want it to work right and be optimized with the phone. I didn't want the update to drain my battery or lag my phone. Glad they're doing it right.
    I think the point was that AOD should have worked with 3rd party apps on the S7/S7E out of the box on day 1. I agree. They half-assed it.
    11-13-2016 11:25 AM
  2. WingLT's Avatar
    I can't find the OTA for Sprint anywhere on the site. All I'm seeing are roms and stuff for rooting the phone. If someone found a link for the OTA for Sprint can you please post the link? XDA is one mess of a site...
    younggreenanne likes this.
    11-13-2016 12:14 PM
  3. Jaycemiskel's Avatar
    There's got to be more to it then that from what I been seeing on YouTube... If something goes wrong with the phone then you are screwed...
    Considering that I've done it, I know there's not more to it. Also, I'm well versed in rooting and romming as I used to do it all the time so I'm not worried about getting screwed. Never bricked a phone and I doubt I'll start now.
    11-13-2016 12:23 PM
  4. ThrottleJohnny's Avatar
    Don't disagree. But we had that discussion way back in March lol. For Note 7 transplants, I'm glad it's coming for Nogurt. Makes the update all the more interesting.
    KPMcClave and merlinskw like this.
    11-13-2016 12:52 PM
  5. Milt K's Avatar
    The only available update.zip file is for VZW. You may be able to flash the VZW bootloader on your Sprint phone via ODIN first and then do the update. No guarantees it'll work but that's how a AT&T customer got the beta to install on his phone.
    If you feel uncomfortable with ODIN and have reservations that this can screw up your phone then don't try it. But for VZW users this is a pretty brainless procedure.
    Hint: Look for a thread called "Galaxy Beta" in the Verizon Samsung S7 Edge forum.
    11-13-2016 01:23 PM
  6. maccauk's Avatar
    Does the always on display get 3rd party notifications like the Note 7 did?
    11-13-2016 03:46 PM
  7. maccauk's Avatar
    Yeah gets everything like note 7
    11-13-2016 03:47 PM
  8. Bryan Havrilla's Avatar
    Love this update its awesome was getting tired of this phone but now nougat wow i might keep it a few more months
    11-13-2016 04:25 PM
  9. James Rogers2's Avatar
    I actually just did it, It really is that easy. Just download it to your SD card and install from there.
    11-13-2016 04:54 PM
  10. maccauk's Avatar
    Not sure if anyone else has mentioned this , but since update my write speeds to sd card have doubled. S7e was apparently capped at 34mb/s which upon testing was about right. Im now getting 70+ write speeds which is better than I got on note 7. Which was apparently capped at about 66mb/s . I'm using 64gb pro+ Samsung sd card.
    11-13-2016 04:56 PM
  11. maccauk's Avatar
    Would post screen shot but not sure how to do it
    11-13-2016 05:00 PM
  12. James Rogers2's Avatar
    I really like the update. Can anyone see a difference in battery life.
    11-13-2016 05:37 PM
  13. granblanco's Avatar
    Does anyone have a smart watch that works with the beta? I'm planning to get the gear S3 soon after launch but I'll wait a while if it's confirmed that it won't work with the beta.
    LG G Watch R and LG Urbane work great
    11-13-2016 05:57 PM
  14. ab304945's Avatar
    Beats me why anyone would want to play the guinea pig for a large corporation ... .
    Especially after Samsungs recent fxxx ups.
    Can't they 'test' it themselves? Samsung must have at least three employees in the phone department.
    They do this to get more testers. They don't have thousands of testers in house
    11-13-2016 07:31 PM
  15. French's Avatar
    If I install the Verizon beta, will there be any issues with installing the future "approved" version? I would hate to have to go back to a factory reset to install the "legit" version.
    11-13-2016 07:31 PM
  16. James Rogers2's Avatar
    From what I was reading on xda you will still be able to get the official ota.
    11-13-2016 07:37 PM
  17. Milt K's Avatar
    You would revert back to the latest stock MM firmware via Odin and take the legitimate OTA if there are any issues, which I don't really foresee since the update file is signed. The only issue that installing an "illegimate" beta is that you're not officially registered to provide and read feedback in the official beta forum. It's always recommended to do a factory restore after a major upgraded such as this beta and when the official Android 7.0 OTA gets installed so you'll be doing them anyway.
    11-13-2016 09:27 PM
  18. steelers1's Avatar
    I'm on Verizon and registered for the beta. My question is do I need to have my sim card installed to download the update? My sim is still in my note 7. When I go to system updates on my s7 edge it says service unavailable.
    11-14-2016 02:32 AM
  19. pjwk81's Avatar
    Android Wear works better now than it ever did. Was a major battery hog in the early days.
    11-14-2016 02:54 AM
  20. Chris Rosas's Avatar
    Hi guys the beta for tmobile users is suppose to be available today. But all I see when I go into the app is server error please try later.
    Has anyone received it?
    Or at what time do you think it will be made available?
    11-14-2016 03:43 AM
  21. aldo82's Avatar
    On the day it came out in the UK, the beta app started working in the afternoon, around 1430 if I remember correctly and the OTA started being released around 2300
    11-14-2016 04:11 AM
  22. tonyron227's Avatar
    I haven't received it yet but hopefully it will start happening later this morning...
    11-14-2016 04:15 AM
  23. kelqwe's Avatar
    Excellent, I'll be ordering one as soon as it's available here then.
    11-14-2016 05:51 AM
  24. Chris Rosas's Avatar
    Like at what time did you get the update?
    11-14-2016 07:13 AM
  25. Thegreatone3's Avatar
    Seeing the same thing so far.
    11-14-2016 07:25 AM
584 ... 45678 ...
  1. Rooted my Galaxy S7... now it's trash
    By EasyOver in forum Samsung Galaxy S7 Rooting, ROMs, & Hacks
    Last Post: 11-26-2016, 03:37 AM
  2. Screen Unresponsive S7 Edge
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 11-10-2016, 05:55 PM
  3. Rooted my Galaxy S7... now it's trash
    Last Post: 11-10-2016, 05:08 PM
  4. Screen Unresponsive S7 Edge
    Last Post: 11-10-2016, 01:27 PM
  5. Replies: 0
    Last Post: 11-10-2016, 12:28 PM
