JDGAFFLIN
I think that was one of the prerequisites for the Beta that the VR wouldn't work. I've a Gear S3 arriving next week and hopefully it's ok.
Ahh, I missed that initially. Thanks!
Yep, I just went and checked the thread where I thought I'd seen it and the first Sprint post was from 2:45 AM ET on the 10th. So, I guess it's true unless he's on the West Coast.
Just worried it can cause issues since it's not available for download as an official update. You guys aren't concerned?
There should be an app on your phone now called "Samsung Members". This is where you can send your feedback among other things.So I have the beta and when I go into the beta app I don't have any options to send feedback. Anyone else having this issue?
Ah ok thank you.There should be an app on your phone now called "Samsung Members". This is where you can send your feedback among other things.
Does anyone know if the battery section if the settings menu is still there?
I couldn't get Good Lock to work at all. You can edit the notification area though. If you fully expand it there's 3 dots beside the settings gear icon top-right that will let you move then around.
I'm loving the update so far, its taking a while to get used to the new settings menu but I'm sure it'll become easier soon. Has anyone used android pay yet? I tried this morning in my usual shop before work and it wasn't picked up at all by the card reader. I've checked the pay app and all the settings I can think of and they all look correct.
Also the out and about feature is gone? I really liked this for setting things like mute and WiFi off at work, wifi on when I got home. Was this a feature on the note? I'd really like to have it back.
It's one of the Edge Panels.Out and About feature....
I've not seen that setting on my s7 edge?
It's categorised under the "device maintenance" section.Nope. Its gone. But u can long press on the Power Saving toggle to go to the battery settings
I did a factory reset and Facebook is working without issue.Anyone got facebook working after doing a factory reset? It worked ok when I updated to nougat but after a factory reset and fresh install of apps it just force closes now and won't open at all
So how long do the rest of us have to wait for this to become available fully? I was trying to register several times and always got the error. Then a message saying that they were maxed limit. It's totally stupid.
I think most of us are "disappointed" because we couldn't get on the Beta train and are reading how great this update is. Coming from the Note7, I'm sure it's a huge improvement in the S7E to close the gap. The fact that the Beta program was so limited in its participation and this information was not known at the onset is the irritating part.Mid to late December according to the beta notes. It's not that long really. I got it on o2 in the UK yesterday. But believe me it's worth the wait. I had to give up my note 7 for an s7 edge. Now my edge feels as good if not better than note 7. It's a mega update. You will not be disappointed.
