1. regsv's Avatar
    Hi I recently had to stop using my Note7 and went back to my Note3. I plan on buying the S7 Edge very soon and I'm wondering if you can tell me how I would be able to use the exact same default keyboard from the Note3 on the S7 Edge? Here is a video of the keyboard (they seem to have it in some dark color mode but the layout is the same) From what I read every new verysion of the samsung keyboard is called "samsung keyboard" so i don't know how to identify that specific one.
    A lot of forum questions seem to be answered with alternatives so i think I should mention my priorities are different than most people's. I have had 3 traumas to the same eye and i simply type much more accurately with this keyboard. Can anyone help? Thanks in advance!
    11-12-2016 04:16 AM
  2. Golfdriver97's Avatar
    I am not sure the keyboard can be moved to a newer device. It will depend if the keyboard is signed to a specific device. I had one time where I tried pulling the calendar from my Galaxy Tab to my S3 and it didn't work. Since we are talking about moving a phone apk to another phone it may not be a big deal.
    11-12-2016 09:48 AM
  3. KPMcClave's Avatar
    In order to do that, there are any number of APK extractors in the Play Store. I'd look for the best rated one and give it a try on the Note 3. I can't say from memory if everything is displayed as extractable in an apk extractor. It may be that the Samsung Keyboard isn't, but it doesn't hurt to try.
    If I had to guess, I'm thinking it won't work. I haven't had much luck with this type of thing (using an apk tied to a specific phone on another phone), although I haven't specifically tried it with a keyboard apk. It may be that your best alternative will be a third party keyboard, but good luck with this. I hope it works for you.
    11-12-2016 11:34 AM
  4. KPMcClave's Avatar
    I should have added that I think the reason this apk extraction idea will fail is because you're going to have a newer version of the Samsung Keyboard already on the S7E, and it is a system app (so it can't be uninstalled without root).
    11-12-2016 11:37 AM
  5. Golfdriver97's Avatar
    I'm honestly thinking the OP is going to run into some kind of signature issue... similar to what you are referring to.
    KPMcClave likes this.
    11-12-2016 02:15 PM
  6. underway99's Avatar
    You can get a similar layout with the Samsung keyboard on the S7 Edge. Scroll down to the bottom of the keyboard settings and activate HIGH CONTRAST KEYBOARDS.
    11-12-2016 03:03 PM
  1. Two separate conversations with the same contact in messenger
    Last Post: 01-25-2017, 05:25 AM
  2. Replies: 1
    Last Post: 11-13-2016, 02:59 PM
  3. Replies: 4
    Last Post: 11-13-2016, 09:30 AM
  4. Replies: 1
    Last Post: 11-12-2016, 11:20 PM
  5. Lenovo A319 problem
    Last Post: 11-12-2016, 04:45 AM
