FWIW, it probably doesn't matter which tempered glass protector you get - they're all about the same. Any of them can be made to stay on very easily. Just put a TINY dab of clear silicone seal on each of the 4 corners of the phone before installing the protector. By pressing down on the 4 corners, the silicone seal will flatten to almost no height, but will help keep the screen protector on. I have no touch-issues and my tempered glass protector has been on for months now with no problems. This works with the cheapest glass protector (I suspect ALL of them are made in the same factory in China).
Hints:
1) Only use a tiny amount of silicone seal - I use the tip of an eyeglass screwdriver to apply it.
2) Be sure to let the silicone dry overnight before using the phone.
3) Try to avoid the two bottom capacitive keys with the silicone seal.
