1. K4r3n46's Avatar
    I'm looking for a good glass protector for my s7 edge. I have bought a couple from eBay which turned out rubbish so I then paid out £25 for a Zagg one and that peeled off the next day so before buying another one I wondered what other people have used and found to be good?
    11-13-2016 04:00 AM
  2. tadpoles's Avatar
    Very satisfied with this one. It's very case friendly.
    11-13-2016 04:20 AM
  3. K4r3n46's Avatar
    Ok thank you I'll see if I can find it on amazon UK thanks
    11-13-2016 04:33 AM
  4. K4r3n46's Avatar
    I can't seem to find it on amazon UK
    11-13-2016 05:13 AM
  5. tadpoles's Avatar
    That's unfortunate.
    11-13-2016 06:30 AM
  6. bandofbrothers2112's Avatar
    I gave up after the 3rd protector I purchased failed.
    11-13-2016 06:36 AM
  7. bertsirkin's Avatar
    FWIW, it probably doesn't matter which tempered glass protector you get - they're all about the same. Any of them can be made to stay on very easily. Just put a TINY dab of clear silicone seal on each of the 4 corners of the phone before installing the protector. By pressing down on the 4 corners, the silicone seal will flatten to almost no height, but will help keep the screen protector on. I have no touch-issues and my tempered glass protector has been on for months now with no problems. This works with the cheapest glass protector (I suspect ALL of them are made in the same factory in China).
    1) Only use a tiny amount of silicone seal - I use the tip of an eyeglass screwdriver to apply it.
    2) Be sure to let the silicone dry overnight before using the phone.
    3) Try to avoid the two bottom capacitive keys with the silicone seal.
    11-13-2016 08:09 AM
  8. tadpoles's Avatar
    Though I'm very very satisfied with the Tanaab protector I found and recommend it highly I think Samsung should do one of these things:
    1. include (or at least sell) their own TGSP
    2. use a material that is more scratch resistant (regular watch faces seem to be more scratch resistant than Corning's Gorilla Glass)
    3. Stop trying to be cute using these curved screens that serve no practical or functional purpose so 3rd parties can more easily meet the demand for screen protection.
    Of course, no one is made to buy Samsung phones but I don't think the above suggestions would hurt Samsung's profits or market share in any significant way.
    11-13-2016 08:25 AM
  9. K4r3n46's Avatar
    Yes I totally agree Samsung should at least have a screen protector to go with it! I did email them and they said it wouldn't be fair to recommend one. So I now have an expensive phone without protection. At the moment I have a cheep film on it as I did drop my phone and it hit the edge and cracked the screen not badly and I could of carried on using it but it was affecting the led in the screen so had to get it repaired had I not had insurance it would of cost me £200. If I'd known how delicate and difficult it was to get screen protectors I would have f just got the S7.
    tadpoles likes this.
    11-13-2016 11:10 AM
  10. JOC2016's Avatar
    I gave up withe glass 3D ones and now have the cheap soft plastic moldable plastic covers on my phones, a huge improvement IMO
    11-14-2016 05:16 PM
  11. JOC2016's Avatar
    After all they are supposed to be Gorilla glass. I just work on the theory that the sticky plastic cover just should help to resist the glass shattering.
    11-14-2016 05:18 PM
  12. mrgigabyte's Avatar
    i went to verizon and had one put on and it stated to come off before i even left there told them to take this junk off my and and went to stapels and got Hip Street Liquid-Armour Screen Protector and no problems dont have to worry about it coming off and with my OtterBox Strada case i feel very well protected
    K4r3n46 likes this.
    11-14-2016 06:07 PM
  13. drmaf894c's Avatar
    I just bought these for mine and my wife's. They are set to arrive tomorrow so we'll see how they go.
    They had the best reviews of many we looked at. Unfortunately with the curved display looks like they all are difficult to get to stay.
    Most have recommended a standard style cover as the best solution but we thought we would give these a try as we have kids who regularly handle our phones and I have been saved time and time again by having a tempered glass protector on my screen.
    Guess we'll see! I'll keep you posted if I can. Headed out of the country on a trip so should be a good time to test it out. Praying I don't hate myself for getting it.
    Redlink Samsung S7 Edge Tempered Glass Screen Protector 3D Curved Full Coverage Ultra Clear Shatter-& Scratch-Proof Screen Protector for Samsung S7 Edge https://www.amazon.com/dp/B01M699KZN...cUvbUpU5565081
    K4r3n46 likes this.
    11-15-2016 11:16 PM
  14. drmaf894c's Avatar
    You might also see if you can find one that doesn't cover the curved portion, that may help them to stay if they are only on the flat surface. Not perfect protection but may be a good solution.
    K4r3n46 likes this.
    11-15-2016 11:17 PM
  15. Hobson123's Avatar
    Tried numerous screen protectors can't get on with any of them so far
    K4r3n46 likes this.
    11-16-2016 05:52 AM
  1. Tempered glass screen cover for the S7
    By Sdzanko in forum Samsung Galaxy S7 Cases & Accessories
    Last Post: 02-13-2017, 09:45 PM
  2. Does the V20 come with a preinstalled screen protector?
    By Jewels81 in forum LG V20 Cases & Accessories
    Last Post: 01-31-2017, 01:46 PM
  3. Cable, Charger and Screen Protector Questions
    By Gebo in forum Moto Z Force
    Last Post: 11-11-2016, 07:49 PM
  4. Dropped phone, cracked something under glass, what should I do?
    By bhaviksheth in forum Samsung Galaxy Note 4
    Last Post: 11-11-2016, 06:57 PM
  5. Does anyone k now where to buy authentic screen protectors?
    Last Post: 11-10-2016, 01:38 PM
