1. Iain Johnson's Avatar
    Hi guys,
    My battery life has gone from amazing to poor within the last couple of months. Did a bit of digging and found that Gear VR (I dont own a VR) was using a high percentage of battery but so was Knox.
    I used package Disabler pro and managed to stop the Gear but then after a full night charge I noticed my battery had dropped 10% within 30 mins. Had a check round and Knox setup was there and using 5%... This has been disabled so what I'm asking is, is this common recently? Is it impossible to stop Knox?
    Sorry if this is a repeat, I've looked but can't find anyone else with this issue.
    11-15-2016 02:36 AM
  2. Zyphen4866's Avatar
    So far KNOX has found ways to re-enable itself after i use PDP to disable it. And it uses a whopping 15% of power for me.
    11-20-2016 09:35 PM
  1. S7 Edge and Facebook Messenger app - unbeliavable LAG
    By bonq07 in forum Samsung Galaxy S7 edge
    Last Post: 05-08-2017, 05:11 PM
  2. Supcase Unicorn Beetle Pro v i-Blason Armorbox
    By n-strike in forum Google Nexus 6
    Last Post: 11-17-2016, 01:53 AM
  3. Replies: 1
    Last Post: 11-15-2016, 04:04 AM
  4. Replies: 1
    Last Post: 11-15-2016, 04:02 AM
