1. venom0706's Avatar
    I've used Clean Master on all of my Android phones so far. However, I noticed that the S7 Edge has an in-built Smart Manager, which essentially does the same job. So, do you think Clean Master is necessary or Smart Manager will be enough for keeping the phone fresh?
    11-16-2016 03:22 AM
  2. aldo82's Avatar
    I have never used anything like clean master on any of my android phones so in my opinion you don't need it. If you want that sort of functionality then yes, use the feature built in.
    Philip Grombliniak likes this.
    11-16-2016 03:30 AM
  3. amyf27's Avatar
    I'd just go with the built in smart clean
    11-16-2016 03:45 AM
  4. chanchan05's Avatar
    No. You should never use anything made by Cheetah Mobile. Plus stuff like clean master and other booster apps are just selling you snake oil.
    sdmf likes this.
    11-16-2016 04:08 AM
  5. Nakrohtap's Avatar
    In Smart Manager under Storage, it says "Powered by Clean Master". I would assume having the Clean Master app would be redundant.
    11-16-2016 05:26 AM
  6. Rumblee1's Avatar
    You dont need clean master or any of those cleaning apps. All they do is use battery. All you need to do is go into settings, hit storage, wait for it to load, then hit cache and clear it. Takes acfew seconds.
    11-16-2016 06:50 AM
  7. Rumblee1's Avatar
    Just curious, why no cheetah mobile products?
    11-16-2016 06:56 AM
  8. Laura Knotek's Avatar
    Please see the following link. http://forums.androidcentral.com/ask...practices.html
    Sam_Gs7 and sdmf like this.
    11-16-2016 08:32 AM
  9. Johnston212's Avatar
    Someone actually interviewed the developer and asked him a lot of questions about it, since he couldn't find that it actually did anything.
    11-16-2016 09:18 AM
  10. Sam_Gs7's Avatar
    Yeah! As pointed out above-This app it's been reported
    as buggy lately. @venom0706 try both if not works
    for you try CCleaner free it does oxon job..Bye
    11-16-2016 10:34 AM
  11. chanchan05's Avatar
    It's not buggy. It's basically malware.
    11-16-2016 04:29 PM
  12. justin1578's Avatar
    You dont need any of that mess, battery savers, none of it.
    Laura Knotek likes this.
    11-16-2016 08:05 PM
  13. Fit24's Avatar
    I've never used any optimizers, junk file cleaners, speed boosters, battery savers, etc. I don't think they are necessary.
    11-17-2016 09:16 PM
  14. Smith 001's Avatar
    Oh,I don't realize that.I would install such clean master app as soon as I got my phone.....
    11-18-2016 03:01 AM
  15. wendywatson's Avatar
    I think we need a clean tool for our phones. Maybe clean master or something else. I have used an app named Space Cleaner for a long time.I think it is useful and fast.It helps me to clean lots of junks. You can have a try~
    https://play.google.com/store/apps/d...lean.spaceplus
    11-21-2016 01:01 AM
  1. How do i turn my status bar back on on my galaxy s6
    Last Post: 11-17-2016, 04:06 AM
  2. How.do.Iocate my lost or stolen cell phone
    Last Post: 11-16-2016, 04:20 AM
  3. Note 5 How do I transfer pics to my Mac
    Last Post: 11-16-2016, 12:23 AM
  4. Replies: 1
    Last Post: 11-15-2016, 08:22 PM
  5. Replies: 1
    Last Post: 11-15-2016, 07:04 PM
