1. Carol Britton's Avatar
    I bought a Samsung Galaxy S7 edge in Europe (SM-G935F), which says my phone is global. I have talked on it for more than 5 minutes using a SIM card here in Belgium. So I think that means my phone is now unlocked.
    So, when I go to the USA next year, can I put an ATT or Verizon SIM card in it?
    I'm just not sure I understand the unlocked or locked terms, or even why on the box of my phone it said it was only for use in Europe.
    11-16-2016 02:57 PM
  2. SpookDroid's Avatar
    Unlocked phones mean that it's not restricted to using with any carrier's SIM. BUT Samsung does 'lock' their unlocked phones to a certain region (but this is a temporary lock to deter gray imports). That additional lock just requires the phone to use any SIM card from the region it was intended to be used/sold in for the first call; once this is done, the phone is now fully unlocked. If you've already used it in Beligium, it probably is already unlocked.
    Now to the 'good' stuff: You still need to check network compatibility. Unfortunately, even though a phone might be 'global', Europe's networks and US ones aren't compatible. So depending on how many frequencies/bands the phone supports, you might not be able to use 4G in the US (or not even 3G in some cases). But for calls, it should work for the most part.
    If the phone doesn't support any band/frequency in the US, then no matter that it's unlocked, it simply won't be able to 'talk' with the networks here.
    Law2138 likes this.
    11-16-2016 03:08 PM
  3. Law2138's Avatar
    Thanks for the explanation. Here's that list you mentioned.
    https://www.bhphotovideo.com/c/product/1225381-REG/samsung_sm_g935_32gb_slv_galaxy_s7_edge_g935.html
    Click on North American Carriers
    SpookDroid likes this.
    11-16-2016 03:16 PM
  4. Carol Britton's Avatar
    Thank you both for your replies. I thought I'd have to buy a new phone to use while in the USA for a couple of months next year. This sounds like a good solution.
    11-18-2016 03:50 PM
  1. Replies: 1
    Last Post: 11-18-2016, 05:01 AM
  2. How do I slow down the slideshow speed while using my VR?
    Last Post: 11-18-2016, 04:59 AM
  3. Why i cannot to do recovery on htc m9?
    Last Post: 11-17-2016, 05:05 AM
  4. Replies: 1
    Last Post: 11-16-2016, 08:35 PM
  5. Why won't Google Play let me add my credit card number
    Last Post: 11-16-2016, 02:32 PM
