1. ClintRo's Avatar
    So the last two days I noticed the Wifi icon in the quick settings would turn on briefly then back off.... like the Wifi was scanning.
    I figure this can reduce battery life so I started looking around and found that it was because the Wifi was trying to help location. I never noticed this before. So I started playing with settings and went into the settings menu --> Location --> Improve Accuracy and turned off Wifi scanning. As soon as I did this it stopped.
    If you scroll the notification drawer down and have Wifi as one of your Quick toggles you will see it in there. LMK if you see the same thing and it fixes the issue. I am on a Verizon S7 Edge.
    11-17-2016 11:03 AM
  2. VW Maverick's Avatar
    11-17-2016 12:28 PM
  3. IAmSixNine's Avatar
    Already mentioned here
    http://forums.androidcentral.com/sam...ml#post5567338
    and
    http://forums.androidcentral.com/sam...ml#post5566973
    even though this is a note 4 forum its the same issue.
    11-17-2016 02:12 PM
  4. Jaycemiskel's Avatar
    Yeah I've been having that issue as well. It's new though. I had never had it in the past. I figured that solution out as well. It was getting annoying.
    11-17-2016 06:01 PM
  5. Chris5626's Avatar
    Just started getting this yesterday on my S7 Edge plus.
    11-19-2016 01:52 PM
  6. dmpotter's Avatar
    Basically about the same time my note 5 started doing it. Always having to make sure, before youtube/netflix is starting to suck.
    11-24-2016 01:04 PM
  7. ClintRo's Avatar
    Yea... I search but didn't find the other threads maybe because of the device specific terms I used.
    11-24-2016 01:17 PM
  8. tennislvr8's Avatar
    I think I found a solution, well it works for me. Check your WiFi setting and see if there is a password for 5G, if there is remove it. That fixed the issue for me.
    11-24-2016 02:05 PM
  1. Galaxy S7 Edge WiFi Turning Off and On Repeatedly
    By Nic Zibelli in forum Samsung Galaxy S7 edge
    Last Post: 12-18-2017, 10:33 PM
  2. Chrome on S6 not opening to set home page
    By williamhcraft in forum Samsung Galaxy S6
    Last Post: 11-17-2016, 11:44 AM
  3. Can I change the size of the text on my home screen?
    Last Post: 11-17-2016, 11:03 AM
  4. my Samsung on7 has been restarting on its own why?
    Last Post: 11-17-2016, 09:48 AM
  5. Why doesn't my BT200 headphones show up on my Nexus 7 tablet?
    Last Post: 11-17-2016, 09:18 AM
