Originally Posted by
Shadowpdx I saw a post in the Chromecast forum mentioning this very problem. Could be a setting on the YouTube app. I reached the forum thru the app that control Comcast.......Apps -> Home -> Help and Feedback. You can do a search on "Disabling Automatic Casting"
Shadowpdx,
Thank you so much for your reply to my question! Your suggestion led me to the solution to my problem. Specifically, for anyone else that comes across this thread in the future, here is the link to the post in Google's own Chromecast Forum:
https://productforums.google.com/for...st/00b79rIKacA
Within that thread, user "jilllG" posted a link to an article that was the solution to my problem, and that article is here:
Google Play services v10 can show a notification with player controls anytime a device on the network is Casting [APK Download]
Basically, a recent update to Google Play Services (to version 10) on Android devices introduced a feature where other users on the same WiFi network are notified if someone else is using a Chromecast device at the moment (and which device they are using), and/or that recent Google Play Services update enabled such notifications to be turned on by default. The solution was to turn those notifications off on all of my family's devices (including my own), and instructions on how to do that are provided in the last link I provided above.
Thanks again Shadowpdx for pointing me in the right direction!
