How do products like Isyncer work? Do I have to be near my computer at all times where my music is to sync a playlist from iTunes to my phone?
So I can't be at work listening my iTunes playlist from my phone after I've synced everything?
Sorry I wasn't clearer. Thanks for your help.Once it's synced it'll be on your phone. Either on your sd card or phone memory (however you set it up). I thought you meant during the initial sync process.
OK thanks. I'll try that.I tried isyncr, but found it kinda slow. The way I transferred my music from iTunes was to create a folder on my desktop. Then I dragged the album's, playlists, and podcasts into that folder. Inserted my micro sd card into my MBP, and transferred the folder to it. It was much faster than isyncr.
I must be super slow because I could not figure out the drag and drop thing, but I remembered I had a program on my computer that copies my songs from my iPod to my computer. So I just copied the songs from the playlist to a folder on my SD card. Thanks again for the help.
