1. sweetypie31's Avatar
    How do products like Isyncer work? Do I have to be near my computer at all times where my music is to sync a playlist from iTunes to my phone?
    11-22-2016 12:37 AM
  2. msm0511's Avatar
    If I remember correctly, yes. They have to either be connected via a cable or on the same wifi network.
    sweetypie31 likes this.
    11-22-2016 08:33 AM
  3. patstar5's Avatar
    You download Isyncr for your Mac/PC and then goto the app and click wifi sync and choose the playlists you want to sync.
    I've been using it since 2014. Recently got a Google play music subscription so I might not be using it anymore.
    11-22-2016 10:07 AM
  4. sweetypie31's Avatar
    So I can't be at work listening my iTunes playlist from my phone after I've synced everything?
    11-22-2016 10:57 AM
  5. msm0511's Avatar
    Once it's synced it'll be on your phone. Either on your sd card or phone memory (however you set it up). I thought you meant during the initial sync process.
    11-22-2016 11:00 AM
  6. sweetypie31's Avatar
    Sorry I wasn't clearer. Thanks for your help.
    11-22-2016 11:01 AM
  7. msm0511's Avatar
    iSyncr is basically a transfer tool. An easier way to get your media from iTunes to an Android phone if you use a Mac.
    11-22-2016 11:01 AM
  8. sweetypie31's Avatar
    I just wanted to make sure I could use it before I bought it.i accidentally erased my playlist from power amp that took me hours to put together. It's hard as heck trying to make a playlist from the 7k songs I have on my phone using power amp. Lol
    11-22-2016 11:06 AM
  9. msm0511's Avatar
    I tried isyncr, but found it kinda slow. The way I transferred my music from iTunes was to create a folder on my desktop. Then I dragged the album's, playlists, and podcasts into that folder. Inserted my micro sd card into my MBP, and transferred the folder to it. It was much faster than isyncr.
    11-22-2016 11:13 AM
  10. sweetypie31's Avatar
    OK thanks. I'll try that.
    11-22-2016 11:35 AM
  11. sweetypie31's Avatar
    I must be super slow because I could not figure out the drag and drop thing, but I remembered I had a program on my computer that copies my songs from my iPod to my computer. So I just copied the songs from the playlist to a folder on my SD card. Thanks again for the help.
    11-22-2016 09:11 PM
  12. sweetypie31's Avatar
    I I did still try iSyncr and I found that it doesn't sync the playlist I made on my iPod. The only playlist that come up are the quick playlists on iTunes. Glad I did not buy it lol
    11-22-2016 10:02 PM
  13. msm0511's Avatar
    Glad you got it figured out!
    11-22-2016 11:44 PM
  1. Software updates and general support
    By Kayza in forum Axon 7 & Axon 7 mini
    Last Post: 01-20-2017, 12:29 PM
  2. Replies: 2
    Last Post: 11-22-2016, 07:03 AM
  3. Safe mode and sense home issue?
    By mwake4goten in forum HTC 10
    Last Post: 11-21-2016, 10:48 PM
  4. Is it possible to unlock a sprint note 4
    Last Post: 11-21-2016, 10:37 PM
  5. my blu touchbook 7.0 crash wat can i do. it wont do anything
    Last Post: 11-21-2016, 10:32 PM
