1. Mario Zhivago's Avatar
    Somehow when I click on it it doesn't turn it on, but when I press click it takes me to the WiFi page and I switch the toggle to on it goes back to off and I have to it a few times to keep it on. Anyone how to fix?
    11-24-2016 08:27 AM
  2. B. Diddy's Avatar
    Have you already tried wiping the cache partition? https://support.t-mobile.com/docs/DOC-28028
    Does it persist in Safe Mode? https://support.t-mobile.com/docs/DOC-28008
    11-25-2016 01:25 AM
  3. SamCarterX302's Avatar
    Have you turned off Wi-Fi Scanning? Sometimes that causes Wi-FI to toggle on and off repeatedly.
    Settings > Privacy & Safety > Location > Improve Accuracy > Wi-Fi- Scanning.
    B. Diddy likes this.
    11-25-2016 03:48 AM
  4. BrayanP's Avatar
    Same issue here, the wifi keeps toggling
    11-28-2016 09:30 AM
  5. B. Diddy's Avatar
    Welcome to Android Central! Since there have already been a couple of responses with suggestions to try, can you tell us if you've already tried them?
    11-28-2016 04:40 PM
  6. IAmSixNine's Avatar
    Also mentioned here, post 4 is my issue post 6 is a work around, but its the same as post 3 here.
    http://forums.androidcentral.com/sam...ml#post5567380
    11-30-2016 11:54 AM
  1. Replies: 1
    Last Post: 11-25-2016, 04:33 PM
  2. Wifi not turning on
    By Claret2KFC in forum Samsung Galaxy S6 edge
    Last Post: 11-25-2016, 01:26 AM
  3. Replies: 1
    Last Post: 11-24-2016, 03:34 PM
  4. Stuck on software update
    By willie5094 in forum Samsung Galaxy S7 edge
    Last Post: 11-24-2016, 07:22 AM
  5. LGG5 Volume keys not responding
    Last Post: 11-24-2016, 07:12 AM
