1. mfldmike's Avatar
    I know that I could root different carrier ROMs onto the Note 7 when I had it without anything special.
    I had a US Cellular Note 7 and flashed AT&T Firmware on it, is it possible to do this with a S7 Edge as well???
    Phone is SIM Unlocked
    11-24-2016 09:22 PM
  2. NexusGirlX's Avatar
    The US versions of the S7 Edge have a locked bootloader so flashing any ROM other then stock is not possible.
    11-24-2016 10:03 PM
  3. mfldmike's Avatar
    I was under the impression that the note 7 also had a locked bootloader...but I was able to install on that device
    11-24-2016 10:30 PM
  4. NexusGirlX's Avatar
    If you look on the XDA developers site, you will see that this is not possible at this time. I had my T-Mobile S7 Edge rooted but that is all that was and is currently possible.
    11-24-2016 10:32 PM
  5. mfldmike's Avatar
    I can actually confirm it works with Official Firmware.
    My device was SM-935RZ
    I flashed SM-935U
    11-24-2016 11:56 PM
  6. NexusGirlX's Avatar
    What works? That must be a non US version. Searching Google for that model number brings up nothing.
    11-24-2016 11:57 PM
  7. mfldmike's Avatar
    I flashed Official non-carrier rom on my device...
    My S7 is a US CELLULAR model and I flashed the Universal firmware
    11-25-2016 12:00 AM
  8. NexusGirlX's Avatar
    Not sure how. Even the unlocked US versions have a locked bootloader.
    11-25-2016 12:01 AM
  9. mfldmike's Avatar
    In other words, if I wanted to flash AT&T or Verizon Firmware I'd be able to...as long as it is Officially released by the carriers
    11-25-2016 12:02 AM
  10. NexusGirlX's Avatar
    Ok so what's the point in that then? The idea of being able to flash a custom ROM was being able to block ads in apps, remove unwanted apps and make the phone do other things the stock ROM doesn't allow you to do.
    11-25-2016 12:05 AM
  11. mfldmike's Avatar
    Because I didn't want US Cellular carrier bloatware if I have AT&T as a service provider. Also flashing a different ROM allows me to use band 17 on AT&T.
    11-25-2016 12:06 AM
  12. NexusGirlX's Avatar
    Good enough.
    11-25-2016 12:08 AM
  1. Need help flashing stock rom for Virginia mobile lg ls665
    By Bricked01 in forum General Help and How To
    Last Post: 11-24-2016, 08:06 AM
  2. Replies: 1
    Last Post: 11-23-2016, 03:52 PM
  3. Stock firmware from another country or carrier
    By Dave Begue in forum Samsung Galaxy S7 edge
    Last Post: 11-23-2016, 03:23 PM
  4. How to backup all data to PC, root and install custom ROM
    By masterton in forum Ask a Question
    Last Post: 11-23-2016, 04:15 AM
  5. Why am I losing small amounts of money to my carrier?
    Last Post: 11-21-2016, 02:11 PM
