1. cassar82's Avatar
    I just recently changed over to the s7 edge from iPhone and the videos I recorded on my iPhone is there any thing I can use to convert them so I can play them on my phone
    11-25-2016 05:32 PM
  2. chanchan05's Avatar
    They don't play? If you used Smart Switch to transfer, AFAIK they should have converted automatically. If not, you can always download VLC or KMPlayer or MXPlayer from the Play Store. They usually play more formats than the default video app.
    11-25-2016 06:47 PM
  3. cassar82's Avatar
    I didn't use smart switch to transfer files. I just need a few videos converted to my camera roll so I can make a video for my business as the app I'm using needs the video from my camera roll
    11-25-2016 07:09 PM
  4. chanchan05's Avatar
    Ah. So it's the problem of the app you are using to make a video, not the phone itself. Does it need to be that app? Is there ah reason why not do the editing on proper editing software on a computer?
    11-25-2016 08:30 PM
  5. SamCarterX302's Avatar
    To play the videos (without converting), get MX Player (or VLC) from the app store.
    To convert, I suggest doing so on your computer.
    If you absolutely must convert the videos using your phone for whatever reason, search for "video converter" on the play store and have a look at the avaialble apps. I've never converted videos with my phone, so I can't recommend any myself.
    thecomicbookandme likes this.
    11-25-2016 08:37 PM
  6. Laura Knotek's Avatar
    If you use VLC for Android, then you shouldn't need to convert anything. It should just play in VLC.
    11-25-2016 09:23 PM
  1. Video Of My GEAR S3 LTE Is Up : )
    By BOSSY TEXAS CHICK in forum Samsung Gear S3
    Last Post: 12-01-2016, 10:23 PM
  2. Amazing video created By Samsung Galaxy S7 Edge - slow motion
    By hamza petra in forum Samsung Galaxy S7 edge
    Last Post: 11-24-2016, 04:51 PM
  3. Replies: 2
    Last Post: 11-24-2016, 02:18 PM
  4. Replies: 2
    Last Post: 11-24-2016, 01:56 PM
  5. Saving photos and videos to SD Card Samsung J5
    By MzSweet in forum Ask a Question
    Last Post: 11-23-2016, 06:43 PM
