1. Aaadd1's Avatar
    I have a smasung galaxy s7 edge i put it in water after i pull it from the water and dry it i put my phone in charge then shows in the notification cable charging instead off fast charging and it takes 6 hour to full charge i tried another cable and did'nt work and tried another phone on the same charger and it charge fast what is the problem
    11-26-2016 11:48 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Moved to the S7 edge forum. It's always possible that a component did in fact get damaged by water. Although they certify it for water resistance, they can't guarantee that the phone will be completely impervious to water damage -- it says this in the manual:
    "This device is rated IP68 using the Ingress Protection rating system. Your device has been tested in a controlled environment and shown to be water and dust resistant in certain circumstances (meets requirements of classification IP68 as described by the international standard IEC 60529 - Degrees of Protection provided by Enclosures [IP Code]; test conditions: 15-35°C, 86-106 kPa, 5 feet, for 30 minutes). Despite this classification, your device is not impervious to water damage in any situation." (From the manual for the Verizon variant)
    thecomicbookandme likes this.
    11-28-2016 12:16 AM
  3. bandofbrothers2112's Avatar
    I'm wondering why you "put it in water" ?
    11-28-2016 02:17 AM
  4. chanchan05's Avatar
    You have to consider what kind of water. Did it have corrosives? It could have damaged the exposed terminals for the charger. Was it moving water? How fast? Moving water could have exerted pressure on the charging port. The S7 is not rates for pressurized water.
    B. Diddy likes this.
    11-28-2016 03:43 AM
  1. Wireless charging intermittently not working
    By Snareman in forum Samsung Galaxy S7 edge
    Last Post: 12-27-2016, 09:08 PM
  2. Bricked my phone, but not really. How do i fix it?
    Last Post: 11-26-2016, 12:46 PM
  3. Replies: 1
    Last Post: 11-26-2016, 12:32 PM
  4. Cache Cleaner that works for Android 6+
    By AllenRulz in forum Android Apps
    Last Post: 11-26-2016, 11:27 AM
  5. i have a samusung galaxy camera and im not happy
    Last Post: 11-26-2016, 09:19 AM
