I got one from Bestbuy on VZ on the 24th. Carol blue. Great deal. I attempted to put Nova Prime on it but the resolution is a bit off. Not sure what is going on but something is not right with Nova on s7 edge. It just doesn't feel "polished". I'm not a newbie for Nova and I'm not sure why it is looking strange.
1st image is touchwize and 2nd is Nova with Pixel icon set. Look at the widgets and Google search. They are just too pig. Feels like resolution is off on the clock widget and water widget. They look much better on touchwize. Even google search looks so big and just not polished like it looks on touchwize. And no, I can't get them any smaller.What's off?
View attachment 246897View attachment 246898
It's the one that came default on my s7 edge.Is that the stock google now search widget or a custom one? Mine doesn't look like that. Yours look nice and new and modern and beautiful. Mine looks like a simple white rectangle -.-
Oh and btw yes I put nova on all my Samsung phones. Makes it feel snappier. No nova on any other phone.
NOVA was the first thing I out on it, I put NOVA on all my phones.
It will turn into a circle when you drag it over.
For making the icons similar, go into Settings->Display and Wallpaper->Icon Backgrounds. Change to Icons with Backgrounds and touch Done.
If it's greyed out, you probably have installed a theme.
Not sure how his search widget looks like that. I also have the Coral Blue with all the updates available and it has the normal search bar.
EDIT: Looks like it's kind of luck of the draw who gets it:
https://verdictforu.com/2016/11/03/...roid-reportedly-getting-a-circular-face-lift/
