1. mysamsung7's Avatar
    I notice that at times I have to press harder to type is that because of the screen protector?
    11-27-2016 11:24 PM
  2. Morty2264's Avatar
    My initial response would be no. But I suppose it would depend on the specific screen protector and/or how it was applied. Did you happen to use the device before the screen protector had been installed? How did the screen sensitivity fare then?
    11-27-2016 11:41 PM
  3. mysamsung7's Avatar
    Never used it before
    11-28-2016 12:01 AM
  4. chanchan05's Avatar
    The screen protector itself may be a bit raised off the phone screen surface.
    11-28-2016 04:44 AM
  5. msndrstood's Avatar
    Yes I have to press harder in the lower left corner but it's gotten less so over time.
    11-28-2016 10:07 AM
  6. HMBgal's Avatar
    Yes. Had the Otterbox tempered glass one and it drove me nuts. Took it off after a couple days. Expensive lesson.
    11-28-2016 10:51 AM
  7. mysamsung7's Avatar
    That's what I had. Took it off
    11-28-2016 11:10 AM
  8. mysamsung7's Avatar
    So you don't have any now?
    11-28-2016 11:10 AM
  9. sweetypie31's Avatar
    I use the HD contour on from bodyguardz and I have no issues with typing on the screen. Mine is just a regular plastic one. It might be different with a tempered glass one though.
    11-29-2016 04:21 AM
  10. HMBgal's Avatar
    No, no screen saver. I use a wallet style case so the screen is covered when it's in my bag or whatever. The screen seems pretty tough, relatively speaking.
    12-15-2016 10:16 PM
  1. Battery is draining and not charging with charger plugged in
    By MadameEsq2You in forum Samsung Galaxy Note 4
    Last Post: 11-29-2016, 04:03 PM
  2. Replies: 1
    Last Post: 11-28-2016, 12:42 AM
  3. Replies: 1
    Last Post: 11-28-2016, 12:18 AM
  4. I shared music that i copied to the clipboard
    Last Post: 11-27-2016, 09:39 PM
  5. Why are green boxes popping up all over screen?
    Last Post: 11-27-2016, 08:10 PM
