1. jgraves1107's Avatar
    Anyone having seriously bad battery drain today? I have started dropping fast. Like 8% in 30 minutes.
    11-28-2016 03:34 PM
  2. B. Diddy's Avatar
    Can you show us some battery stats? Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    11-28-2016 04:24 PM
  3. jgraves1107's Avatar
    Oh I figured it out. One drive is uploading everything for some reason.
    B. Diddy likes this.
    11-28-2016 06:06 PM
  1. Switching to Verizon with unlocked 6P?
    By mkchillin in forum Nexus 6P
    Last Post: 11-29-2016, 03:29 PM
  2. Battery is draining and not charging with charger plugged in
    By MadameEsq2You in forum Samsung Galaxy Note 4
    Last Post: 11-29-2016, 03:03 PM
  3. Battery Life
    By paininthenuts in forum Moto G (2015)
    Last Post: 11-28-2016, 06:08 PM
  4. Battery life
    Last Post: 11-28-2016, 12:11 AM
  5. Perserving Battery life
    By Abbers727 in forum Samsung Galaxy S7 edge
    Last Post: 11-27-2016, 11:16 PM
