I have noticed that on my Yootech screen protector (applied with water to the S7 Edge screen), there are very tiny bubbles left on it, even after drying. They are not even bubbles, but small protector dents or distortions, as the protector itself looks completely flat and smooth when observed from different angles.
My question is: Are these moisture spots trapped under the protector and can that moisture go through the display and damage the phone in the long run? Or are they simply protector distortions and really nothing to worry about? I am 99% sure it's the latter, as it's been almost a week since I applied the protector and all other water bubbles dried out and disappeared completely. We are talking about 2-3 very tiny bubbles here.
Thank you and appreciated.
