1. venom0706's Avatar
    I have noticed that on my Yootech screen protector (applied with water to the S7 Edge screen), there are very tiny bubbles left on it, even after drying. They are not even bubbles, but small protector dents or distortions, as the protector itself looks completely flat and smooth when observed from different angles.
    My question is: Are these moisture spots trapped under the protector and can that moisture go through the display and damage the phone in the long run? Or are they simply protector distortions and really nothing to worry about? I am 99% sure it's the latter, as it's been almost a week since I applied the protector and all other water bubbles dried out and disappeared completely. We are talking about 2-3 very tiny bubbles here.
    Thank you and appreciated.
    11-29-2016 07:17 AM
  2. ZOMMBIE1's Avatar
    I wouldn't worry about it. Even if moisture bubbles I doubt they would hurt the device. Hit it with a blow dryer if you haven't already. If that don't dry them out its probably just the screen protector itself.
    11-29-2016 08:37 AM
  1. Airplane mode. Is it good for the Cinema
    By gfplux in forum Huawei P9 & P9 Plus
    Last Post: 11-29-2016, 04:49 PM
  2. Can't pair Bluetooth to mdrx-b950bt headphones
    By PlasmodiumClos in forum Nexus 6P
    Last Post: 11-29-2016, 08:18 AM
  3. How can I fix this dark spot on my screen?
    Last Post: 11-29-2016, 06:54 AM
  4. How can you scan your screen for colors
    By SimpleAndroidUser in forum Android Apps
    Last Post: 11-29-2016, 05:55 AM
  5. Replies: 0
    Last Post: 11-29-2016, 05:03 AM
