1. golfergirl13's Avatar
    For the last couple of weeks I have noticed the bluetooth keeps turning on constantly. I have to turn it off at least 6 to 7 times a day. Any suggestions on how to fix it?
    11-29-2016 10:04 AM
  2. B. Diddy's Avatar
    Go to Settings>Privacy>Location>Improve Accuracy, and see if Bluetooth Scanning is turned on.
    11-29-2016 04:35 PM
  3. golfergirl13's Avatar
    It was turned on therefore I turned it off.
    11-29-2016 10:15 PM
  4. B. Diddy's Avatar
    Sorry, are you saying that you found that setting and it was turned on? If so, let us know if turning it off seems to stop the problem.
    11-29-2016 10:37 PM
  5. golfergirl13's Avatar
    After turning the Bluetooth scanning off it still did not fix the problem. :-(
    11-29-2016 10:58 PM
  6. B. Diddy's Avatar
    Does it happen in Safe Mode? https://support.t-mobile.com/docs/DOC-28008 This can help narrow down the problem to something you installed vs a system or preinstalled app.
    11-30-2016 02:35 AM
  7. golfergirl13's Avatar
    It all started around the 17th (Nov) when I installed the latest security update.
    11-30-2016 10:12 AM
  8. golfergirl13's Avatar
    Once I am in safe mode, then where do I go to check?
    11-30-2016 10:16 AM
  9. wookiee2cu's Avatar
    My wifi got buggy after the recent T-Mobile update. I go to turn wifi on, the notification button will repeatedly turn on and off. Had to go to Settings>Privacy>Location>Improve Accuracy and turn off wifi scanning. My guess is that update had a few bugs in it, however my co-workers S7 Edge who is also on T-Mobile doesn't have the issue but he did just get his phone and did the update before he set everything up on his phone.
    11-30-2016 12:28 PM
  10. golfergirl13's Avatar
    Yea, I have already gone to Settings>Privacy>Location>Improve Accuracy > bluetooth scanning. I have turned it off AND on and still the bluetooth keeps turning on. It is so frustrating.
    11-30-2016 12:31 PM
  11. B. Diddy's Avatar
    The same way you see that Bluetooth is coming on now. I assume you're seeing the icon appearing in the status bar. Or you could go to the Settings>Bluetooth menu and watch it for a while in Safe Mode, to see if the switch turns on by itself.
    You could also try reinstalling the firmware using Smart Switch, in case something went wrong with the system update: SmartSwitch: Install & update or replace firmware
    thecomicbookandme likes this.
    11-30-2016 07:03 PM
  12. golfergirl13's Avatar
    Ok, I put the phone in safe mode for over 2 hours and the bluetooth did NOT turn on at all? So what could be causing it?
    12-01-2016 12:19 PM
  13. B. Diddy's Avatar
    This is the tedious part. Unless there's an app you suspect, you might just have to do it by trial and error, by uninstalling apps one by one until the problem goes away (in Normal Mode, that is).
    12-01-2016 05:07 PM
  14. golfergirl13's Avatar
    Well, that kind of sucks. LOL Thanks for your help.
    B. Diddy likes this.
    12-01-2016 05:26 PM
  1. Why can't i access my gallery on my S5?
    By Gyro4 in forum Samsung Galaxy S5
    Last Post: 11-30-2016, 06:42 AM
  2. Samsung pay on low battery
    By ttrain68 in forum Samsung Gear S3
    Last Post: 11-29-2016, 03:06 PM
  3. Replies: 2
    Last Post: 11-29-2016, 01:36 PM
  4. How do I send and receive TEXT messages on my phone.
    Last Post: 11-29-2016, 08:43 AM
  5. How can I fix this dark spot on my screen?
    Last Post: 11-29-2016, 06:54 AM
