1. Shamshi-Adad's Avatar
    I know its swiping your palm across some how. Then where does it save to?
    THANKS!
    Peace. Alan
    Galaxy S7Edge [MM6.0.1] Full Dresser
    Lumia ICON [Win10M 14965.1001] Sportster
    Even when I lose, I win.
    11-29-2016 02:47 PM
  2. SpookDroid's Avatar
    If you didn't select the option to let you edit it first, then it goes straight to the SCREENSHOTS folder. If you have the option to show let you edit beforehand, it won't save until you specifically say SAVE (then it goes to the Screenshots folder).
    Shamshi-Adad likes this.
    11-29-2016 02:50 PM
  3. Shamshi-Adad's Avatar
    Thanks, SpookDroid.
    EDIT>>> Perfect! Thanks, man.
    Peace. Alan
    SpookDroid likes this.
    11-29-2016 02:54 PM
  4. LineKill's Avatar
    The screenshots folder will be inside your DCIM folder.
    You can also press the home and power button at the same time for a screenshot, which I find is actually easier for me.
    ToddK and Shamshi-Adad like this.
    11-29-2016 02:56 PM
  5. amyf27's Avatar
    You can also see it clicking on Gallery. Or Google Photos if you auto backup
    11-29-2016 03:12 PM
  1. Double Tap to wake?
    By Melanizm in forum Honor 8
    Last Post: 12-05-2016, 01:06 PM
  2. Galaxy S6 suddenly won't connect to any PC
    Last Post: 11-30-2016, 09:39 PM
  3. How do u contact RingPlus?
    By ElaineA in forum Ask a Question
    Last Post: 11-29-2016, 04:40 PM
  4. What happens to your smartphone when...
    By JimBiggs151 in forum General Carrier Discussion
    Last Post: 11-29-2016, 03:01 PM
  5. Replies: 1
    Last Post: 11-29-2016, 02:50 PM
