1. JM22508's Avatar
    My phone won't auto rotate at all. The option is not in Quick Settings and I can't find it anywhere else. I use Nova, and the auto rotate option is selected in Nova Settings. Any ideas?
    11-29-2016 07:06 PM
  2. chanchan05's Avatar
    Just to be sure, you checked the entire quick settings right? Apart from the ones on top of thr notification bar, you can swipe down on those with two fingers to reveal more. Are you on the beta firmware? Have you tried restarting?
    11-29-2016 07:47 PM
  3. toneyl's Avatar
    It's under Settings/Display and Wallpaper/Screen Rotation
    11-29-2016 09:52 PM
  4. JM22508's Avatar
    Argh! chanchan, not there either. Not on beta and restarted multiple times.
    toneyl, I don't have Wallpaper/Screen Rotation under Display!
    Frustrated.
    11-30-2016 04:03 PM
  5. JM22508's Avatar
    Well, I finally figured it out. I must have inadvertently hit the auto rotate quick setting and when you do so, the name of the link changes to Portrait with a lock icon. I must have overlooked that a thousand times. After tapping portrait, the name changes back to auto rotate!
    chanchan05 and toneyl like this.
    12-01-2016 06:23 PM
  1. Replies: 1
    Last Post: 12-01-2016, 02:39 AM
  2. How can i change my default video app in htc m9plus???
    Last Post: 11-30-2016, 07:47 AM
  3. Phone crashed and now accounts not displaying previous data
    Last Post: 11-29-2016, 06:40 PM
  4. why does my MacBook Air not read my Galaxy Grand Prime?
    Last Post: 11-29-2016, 06:18 PM
  5. Mi lg no conecta con wifi como lo erreglo
    Last Post: 11-29-2016, 05:52 PM
