1. keystone_56's Avatar
    See picture, any help would be appreciated. Thanks
    11-30-2016 05:38 PM
  2. keystone_56's Avatar
    Forgot to add, contact assignments are also missing on the Google web page. I think it shows 5 assigned to a group of over 1k. So I have to assume the note 4 has stripped the group assignments from each contact. But, on the note 4 when I view the groups in the contacts app everything is fine.
    11-30-2016 05:40 PM
  3. keystone_56's Avatar
    11-30-2016 10:43 PM
  4. keystone_56's Avatar
    Further examination reveals all communication is working other than the Note 4 sending group info. For instance if I make a change to any other option on a contact card other than the group assignment, then that info is synced to both my other devices and the the contacts online. If I make a change to the group settings on the note 4 that info is not synced online or on my other devices.
    Any change get made online or on my other devices are 100 percent synced when I view the specific contact on the Note 4.
    12-02-2016 08:27 PM
  5. VDub2174's Avatar
    Please do not create multiple threads about the same topic.
    12-02-2016 10:28 PM
  1. What is Allshare Cast Dongle and S/W Update?
    By rkemp96 in forum Android Apps
    Last Post: 02-21-2017, 07:35 PM
  2. Removing / silencing group texts on Android 6.0 on LG G4
    Last Post: 01-13-2017, 10:37 PM
  3. Contacts Sync from Note 4 to GS7
    By keystone_56 in forum Android 6.0 Marshmallow
    Last Post: 12-01-2016, 07:37 AM
  4. Replies: 1
    Last Post: 11-30-2016, 11:53 PM
  5. Replies: 2
    Last Post: 11-30-2016, 03:22 PM
