1. BlackAudiA5's Avatar
    Aside from turning my Edge 7 OFF at night, how do I keep the display OFF while charging? I've tried just about everything I can find.
    Thanks,
    SP
    Attached Thumbnails How do I keep the display OFF during the night while charging?-2277.jpg
    12-01-2016 09:22 AM
  2. chanchan05's Avatar
    Underneath the option for keep screen off is 'screen saver'. That brings up a display when charging. Turn that off.
    12-01-2016 09:38 AM
  3. BlackAudiA5's Avatar
    Thanks, I'll give that a try.
    12-01-2016 09:42 AM
  4. BlackAudiA5's Avatar
    Didn't work. Got up this morning and the display was on. I noticed that Always On Display was toggled on however.
    Attached Thumbnails How do I keep the display OFF during the night while charging?-2285.jpg
    12-02-2016 09:37 AM
  5. chanchan05's Avatar
    You meant the clock? Yeah that's a feature.
    12-02-2016 04:32 PM
  6. BlackAudiA5's Avatar
    No, more than just the clock. The display... even with Screensaver turned off, I have a full color display lighting up the room, when I get up in the morning. I'll try and get a shot of it in the morning.
    12-02-2016 04:36 PM
  7. Syounger64's Avatar
    Try turning on the power save feature. It might turn off your display.
    12-03-2016 05:04 PM
  8. BlackAudiA5's Avatar
    Looks like PowerSave gets turned off temporarily while charging. I normally charge at night.
    I think it may be related to notifications. Perhaps notifications wakes up the screen, and keeps it on (all night) while charging. All I know is the screen is black when I go to bed and it's ON (although dimmed) with visible notifications when I get up. My Motorolas always kept a black screen all night, no matter what.
    Attached Thumbnails How do I keep the display OFF during the night while charging?-2296.jpg
    12-03-2016 05:16 PM
  9. Tsepz_GP's Avatar
    That is very weird. Are you sure its not some app doing it? Do you have any apps that control e.g. notifications, display etc...?
    12-03-2016 05:19 PM
  10. pappcam's Avatar
    That's not a fix. There's something wrong with his setup because the screen is not supposed to stay on when charging.
    To the OP, do you have the Developer options enabled in your settings? There's an option in there to keep the screen on.
    If not, you have something running that's keeping the screen on all the time.
    12-03-2016 05:20 PM
  11. BlackAudiA5's Avatar
    Just found the answer (I think) on another forum. It lines up exactly with your suggestion.
    "Stay awake" must have been turned on by default. Thanks
    Attached Thumbnails How do I keep the display OFF during the night while charging?-2297.jpg
    12-03-2016 05:25 PM
  1. Screen keeps turning on when using timer
    Last Post: 12-02-2016, 02:21 PM
  2. why do I lose data service completely.
    By androidfan671 in forum General Help and How To
    Last Post: 12-01-2016, 05:15 PM
  3. What are the features of industry level android apps
    Last Post: 12-01-2016, 09:13 AM
  4. Replies: 1
    Last Post: 12-01-2016, 09:11 AM
  5. How to get Chrome, Maps, and Clock to clear?
    Last Post: 12-01-2016, 09:07 AM
