1. mysamsung7's Avatar
    What is your choice?
    12-01-2016 12:19 PM
  2. SpookDroid's Avatar
    I use both. Download a theme for TW that will skin the UI portions that are inaccessible to other launchers and then just use Nova with custom icons.
    sweetypie31 and ghstrdr951 like this.
    12-01-2016 12:30 PM
  3. mysamsung7's Avatar
    Good idea
    12-01-2016 12:36 PM
  4. sweetypie31's Avatar
    Did not know that was possible. I learn something new everyday. Do I add the tw theme first then go back to nova to add my icons?
    12-03-2016 03:35 AM
  5. chanchan05's Avatar
    Won't matter. Just set Nova as default and change the theme via settings. Will change the wallpaper and the stock apps, but won't affect Nova icon packs used.
    I have Nova set as default and change themes without skipping a beat whenever I want.
    12-03-2016 09:23 AM
  6. Ipse_Tase's Avatar
    ^^^ what he said...Nova plus a dark theme just works for me...no need for TW
    sweetypie31 likes this.
    12-03-2016 09:52 AM
  7. sweetypie31's Avatar
    OK. Thanks. I thought I could only use one or the other.
    12-03-2016 04:37 PM
  1. There is no sound on incoming and outgoing calls.
    Last Post: 12-02-2016, 04:44 PM
  2. Replies: 2
    Last Post: 12-01-2016, 02:53 PM
  3. help seeing older emails on my phone
    Last Post: 12-01-2016, 12:41 PM
  4. How do i get the app or widget back for answering calls
    Last Post: 12-01-2016, 11:28 AM
  5. I can't send or receive email in my galaxy 5
    Last Post: 12-01-2016, 11:22 AM
