1. Nemomnis's Avatar
    Hi everybody. I recently purchased a S7 Edge, coming from an OPO. I wanted a top range smartphone and I choose it because of the enthusiastic reviews I had read on the Internet, especially about camera and battery. While I've been very happy about camera, it's absolutely not the same about battery.
    The phone doesn't last more than 12-15 hrs of light use (no games, no 'heavy' apps, no Bluetooth, screen brightness at about 30%, most of background backup disabled). This morning, after a full-night charge, it dropped from 100% to 99% just in a minute of Twitter browsing.
    I checked in the stats and apparently there is no app draining the battery; yesterday the top energy consumption came from the screen.
    In addition, it gets easily warm on the screen and on the back (not hot), and I'd like to know if it is normal. I'm using it without any case, just as I did with my OPO, but the latter has always been cold, even during heavy use.
    I'm posting some screenshots about the battery stats in my Settings.
    Attached Thumbnails Battery drain with light use on S7 Edge... Is this normal?-screenshot_20161203-082328.jpg   Battery drain with light use on S7 Edge... Is this normal?-screenshot_20161203-081555.jpg
    12-03-2016 02:39 AM
  2. chanchan05's Avatar
    There's nothing to tell. Let it run a few days until it settles.
    12-03-2016 03:30 AM
  3. Nemomnis's Avatar
    It's been a week today.
    Should I wait longer?
    12-03-2016 03:55 AM
  4. chanchan05's Avatar
    Well we'll need more detailed battery stats, like how long was the screen on during that time. So far what you've shown us is that the duration expected for the phone is 24hrs.
    Download GSAM battery monitor and let your phone cycle a few times.
    12-03-2016 04:03 AM
  5. Nemomnis's Avatar
    OK, I've downloaded and launched GSAM battery monitor. I'll post the collected results. Thanks!
    12-03-2016 04:07 AM
  1. Battery drain with light use on S7 Edge... Is this normal?
    Last Post: 12-03-2016, 08:54 AM
  2. how to unlock screen with forgotten pin
    Last Post: 12-03-2016, 03:33 AM
  3. Why is 4G showing up even though mobile data is turned off?
    By DrunkAzSkunk in forum Android 7.0 Nougat
    Last Post: 12-03-2016, 01:44 AM
  4. why call drop on S6 edge when the screen turned off?
    Last Post: 12-03-2016, 01:38 AM
  5. Why does my battery drain so fast? Help!
    By 12of12 in forum Samsung Galaxy S7
    Last Post: 12-02-2016, 05:00 PM
