1. Conor78's Avatar
    The display that normally sits at the top left of the home screen which gives time and temp etc has disappeared. How do I bring it back??
    12-05-2016 09:27 AM
  2. Rukbat's Avatar
    Have you installed anything or gotten any update? If not, press a blank spot on the homescreen, go to Widgets, and get back the widget that used to be there (probably a weather widget).
    B. Diddy likes this.
    12-05-2016 01:04 PM
  3. B. Diddy's Avatar
    Yeah, it sounds like you're talking about the Time/Weather widget.
    12-05-2016 01:18 PM
  1. My Samsung A7 display is broken
    Last Post: 12-05-2016, 03:51 PM
  2. .how do i reset display color it looks like a negative
    Last Post: 12-05-2016, 06:48 AM
  3. .how do i reset display color it looks like a negative
    Last Post: 12-05-2016, 05:35 AM
