1. jsiddle2025's Avatar
    Anyone have any idea what these numbered items are? Or why s7 edge battery has been draining to 0 in 12 hrs for about a week?
    I usually get 18+ hours because I'm a light user.
    12-05-2016 11:50 AM
  2. jsiddle2025's Avatar
    This is what I ususally get:
    12-05-2016 11:54 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! One of my fellow Ambassadors, Javier P, has noted that items that start with "10xxx" usually represent apps you recently uninstalled. Would that make sense for your first screenshot?
    Also, the high Cell Standby percentage usually means you've been in an area of bad signal. This makes the phone work overtime to latch onto the signal.
    12-05-2016 02:20 PM
  4. jsiddle2025's Avatar
    recently uninstalled quite a bit of apps that i wasnt using, that used to spam my notification center
    12-05-2016 02:29 PM
  5. jsiddle2025's Avatar
    How do i clear those apps from draining my battery if i have uninstalled?
    12-05-2016 02:34 PM
  6. B. Diddy's Avatar
    I don't believe they're currently draining your battery -- I think it's just showing you how much battery they used before you uninstalled them. Let us know if it persists even after a few charge cycles.
    12-05-2016 03:13 PM
  7. jsiddle2025's Avatar
    i restarted the phone and they are still there. ideas?
    12-05-2016 03:35 PM
  8. Javier P's Avatar
    Full charge the phone and see if those processes appear on the next battery cycle.
    B. Diddy likes this.
    12-05-2016 03:39 PM
  1. Battery issues?
    By BoneDigger in forum Moto X
    Last Post: 05-21-2017, 08:03 AM
  2. Replies: 15
    Last Post: 12-06-2016, 09:10 AM
  3. Android System Killing Battery
    By JimK#CB in forum Moto Z
    Last Post: 12-05-2016, 01:14 PM
  4. Review: extended battery case for the S7
    By bsannes in forum Samsung Galaxy S7
    Last Post: 12-05-2016, 07:39 AM
  5. Android System Development - Global Content/File Filter (More than an app)
    By fabbinde in forum Software Development and Hacking
    Last Post: 12-05-2016, 05:02 AM
