1. Tim Bell1's Avatar
    For some strange reason when I press the home button to use fingerprint to open it makes a sound. How do I turn it off
    12-06-2016 05:32 PM
  2. SamCarterX302's Avatar
    What kind of sound do you mean? A hardware noise, like the click of a button, or software noise like tapping a "button" on the screen makes?
    12-06-2016 09:02 PM
  3. Tim Bell1's Avatar
    Like tapping a button on the screen
    12-06-2016 09:08 PM
  4. wookiee2cu's Avatar
    Try settings>sounds and vibration then scroll down to System section and turn off Screen lock sounds, did that fix it?
    12-07-2016 12:33 PM
  5. Tim Bell1's Avatar
    It was off. I did a hard reset and it seems to fix the problem. Have no idea why it started
    12-08-2016 06:44 PM
  1. Operator shows on lock screen but not on home screen
    By AC Question in forum Moto G4 Plus
    Last Post: 12-11-2016, 01:49 PM
  2. Google Home Nest
    By smunro622 in forum Google Home
    Last Post: 12-08-2016, 09:06 PM
  3. S7 Edge Missing Home Icon
    By Chrit in forum Ask a Question
    Last Post: 12-06-2016, 05:31 PM
  4. Skullcandy earphones outputting a fuzzy noise
    Last Post: 12-06-2016, 01:01 PM
  5. Operator shows on lock screen but not on home screen
    Last Post: 12-05-2016, 08:09 PM
